X10 Commands (indigo.x10.*)
Command Syntax Examples |
indigo.x10.sendAddress("A1")
Parameters |
direct parameter | Yes | string | X10 address |
suppressLogging | No | boolean | |
Parameters |
delta | Yes | integer | the amount to brighten by relative to the current brightness - valid values from 1 to 100 |
suppressLogging | No | boolean | a boolean indicating if entries in the event log should be suppressed (default is False) |
updateStatesOnly | No | boolean | use if you only want Indigo's internal device state representation to be updated - no actual X10 commands will be sent (default is False) |
Parameters |
delta | Yes | integer | the amount to dim by relative to the current brightness - valid values from 1 to 100 |
Parameters |
command | Yes | integer | the comand to send |
data | Yes | integer | the data to send |
Parameters |
Parameters |
indigo.x10.sendOn("A1")
Parameters |
indigo.x10.sendOff("A1")
Parameters |
Parameters |
Parameters |
