Indigo includes an integrated web server that allows you to serve your own custom content, and it also includes a web-based alternative to Indigo Touch for iOS called Indigo Touch for Web or ITW. ITW is a Single Page Application (SPA) that runs entirely in a browser. ITW is not meant to be a replacement for the Mac Client – you can't configure devices or add variables for example – however, the most common Indigo functions are available. These include turning on/off devices, controlling thermostats, changing variable values and so on. Available features are listed below and we have plans to include more features in the future!
ITW works by establishing a bi-directional connection to the Indigo Websocket API. ITW works on both desktop and mobile (mobile availability depends on configuration and whether you'e connected locally via WiFi or remotely via cellular).
  1. the Indigo Reflector Service using your custom reflector address such as https://my_reflector.indigodomo.net via a secure https:// connection (the reflector service requires an Indigo up-to-date subscription).
  2. a local loop-back address such as http://localhost:8176 or http://127.0.0.1:8176 via an insecure http: connection. These connections are only valid when used on the same machine running the Indigo server (and obviously, won't work on mobile).
  3. a direct IP address such as http://10.0.1.123:8176 or http://192.168.0.123:8176 via an insecure http: connection.
Tabs
  • The Devices tab shows all the devices in the Indigo database.
  • Only devices with Remote Display checked will be displayed.
  • Many device controls are available in ITW, including:
    • On/off
    • Lock/unlock
    • Dimming
    • Thermostat
Devices also have a special popup menu which is shown when you click the ellipsis icon at the top of the device tile. This displays a menu with up to four options (depending on the type of device):
  • Copy ID - This item will cause the device's ID to be copied to the clipboard. Due to the security of modern browsers, this feature will only work via https connections via the Indigo Reflector Service and via http when connecting using a local loopback address like localhost or 127.0.0.1.
  • Refresh from server - ITW objects update automatically when data are changed in Indigo, but sometimes you might want to force the data to refresh for a specific device. Selecting this item will cause the device data to be refreshed.
  • Send status request - only available for devices that support the Send Status Request feature in the Indigo Client.
  • Show device JSON - this item will cause a pop up window to display the entire JSON payload for the device.
Actions
  • The Actions tab shows all the action groups in the Indigo database.
  • Only actions with Remote Display checked will be displayed.
  • Clicking a displayed action button will cause the action to be executed.
Variables
  • The Variables tab shows all the variables in the Indigo database.
  • Only variables with Remote Display checked will be displayed.
  • You can change the value of any variable (with the sole exception of isDaylight which is read only).
Pages
  • The Pages tab shows all the control pages in the Indigo database.
  • Only control pages with Remote Display checked will be displayed.
  • Clicking a displayed control page button will cause the page to be loaded in a separate window or tab.
Logs
  • The Logs tab shows the 25 most recent event log entries.
  • New log messages will be displayed while the Logs tab is active.
  • Debug, caution and warning messages will be colored appropriately.
In Folder
Name Contains
Light Mode Dark Mode
By default, ITW will show the Devices tab when it first loads. If you would like to begin with a different tab, you can add a URL query argument to the end of the target URL (query arguments must be lower case and you must include index.html as a part of the URL for this feature to work).
Examples:
Tab Target URL Default
Devices http://localhost:8176/index.html?tab=devices X
Actions http://127.0.0.1:8176/index.html?tab=actions
Variables https://my_reflector.indigodomo.net/index.html?tab=variables
Pages http://192.168.0.123:8176/index.html?tab=pages
Logs http://10.0.1.123:8176/index.html?tab=logs
    • https:%%%% when accessing via the Indigo Reflector Service, and * http:%%%% via the other available means.
  • be sure you've entered in the correct address for your Indigo server and the port number you specified when you started the server (the default is 8176).
  • if the proper tab wasn't selected when you loaded the app, be sure your query arguments are lower case ?tab=logs is valid, ?tab=Logs is not.
  • /www/perceptive/wiki/data/attic/indigo_2024.1_documentation/indigo_touch_web.1739142880.txt.gz
  • Last modified: 2025/02/09 23:14
