Safari MacOS
- Open Keychain.
- From the `File` menu, select `Import Items…`.
- Point to
../Web Assets/cert/indigo-cert.pemand select 'Open'. - The security certificate will be added to the 'Login' keychain.
- Keychain will mark the certificate with a warning that “This certificate has not been verified by a third party.”
- Double-click the certificate to open its info pane.
- Maximize the
Trustsettings and find “When using this certificate:” and select “Always Trust”. - Keychain should require a password to save the change.
- You may need to click away from the certificate and then re-select it for the updated settings to be displayed in the Keychain list.
Safari iOS and iPadOS
- On your Mac, browse to the certificate file at
../Web Assets/cert/indigo-cert.pem. - Click on the certificate and select “Share” and use Air Drop to share it to your device.
- On the device, if prompted, select the device you want to install the profile on (e.g., iPhone, Apple Watch, etc.)
- iOS should respond by saying, “Profile Downloaded”. You can close the notification.
- Open the Settings app.
- Near the top, of the main screen, there should be an item, “Profile Downloaded”.
- Click the downloaded profile, review its contents, and then select “Install”.
- Enter your passcode.
- You will be warned, “The authenticity of “Indigo Domotics” cannot be verified.”
- Select “Install”, and then select “Install”.
- Select “Done”
Android
Firefox
- In Firefox, select 'Firefox' > 'Settings…'.
- In the search box, type “Certificates”.
- Select “View Certificates”.
- Select the “Servers” tab.
- Select “Add Exception”.
- Enter the URL for your server. For example,
https://localhost:8176. - Click “Get Certificate”.
- Read the warnings and then select “Confirm Security Exception”.
- You should see the security certificate exception listed in the Certificate Manager.
Chrome
