Only local or direct access to the Indigo Web Server will use the self-sign certificate (if https is enabled in the Start Local Server dialog). The Indigo reflector doesn’t use the local certificate; it’s part of the reflector service, so it’s a valid certificate from a third-party Certification Authority.
Safari MacOS
  1. Open Keychain.
  2. From the `File` menu, select `Import Items…`.
  3. Point to ../Web Assets/cert/indigo-cert.pem and select 'Open'.
  4. The security certificate will be added to the 'Login' keychain.
  5. Keychain will mark the certificate with a warning that “This certificate has not been verified by a third party.”
  6. Double-click the certificate to open its info pane.
  7. Maximize the Trust settings and find “When using this certificate:” and select “Always Trust”.
  8. Keychain should require a password to save the change.
  9. You may need to click away from the certificate and then re-select it for the updated settings to be displayed in the Keychain list.
Safari iOS and iPadOS
  1. On your Mac, browse to the certificate file at ../Web Assets/cert/indigo-cert.pem.
  2. Click on the certificate and select “Share” and use Air Drop to share it to your device.
  3. On the device, if prompted, select the device you want to install the profile on (e.g., iPhone, Apple Watch, etc.)
  4. iOS should respond by saying, “Profile Downloaded”. You can close the notification.
  5. Open the Settings app.
  6. Near the top, of the main screen, there should be an item, “Profile Downloaded”.
  7. Click the downloaded profile, review its contents, and then select “Install”.
  8. Enter your passcode.
  9. You will be warned, “The authenticity of “Indigo Domotics” cannot be verified.”
  10. Select “Install”, and then select “Install”.
  11. Select “Done”
Android
FIXME
Firefox
  1. In Firefox, select 'Firefox' > 'Settings…'.
  2. In the search box, type “Certificates”.
  3. Select “View Certificates”.
  4. Select the “Servers” tab.
  5. Select “Add Exception”.
  6. Enter the URL for your server. For example, https://localhost:8176.
  7. Click “Get Certificate”.
  8. Read the warnings and then select “Confirm Security Exception”.
  9. You should see the security certificate exception listed in the Certificate Manager.
Chrome
  • /www/perceptive/wiki/data/attic/indigo_2024.1_documentation/indigo_web_server_certificates.1723660029.txt.gz
  • Last modified: 2024/08/14 18:27
