Managing Your Z-Wave® Network
Z-Wave Configuration Dialog Image
Using Encryption
Z-Wave Dialog Settings Image
  4. Click on the Sync button.
Z-Wave Menu Image
Manage Associations
Send Raw Z-Wave Command
Stop Inclusion / Exclusion
Optimize Z-Wave Network
If a Z-Wave device is no longer available to your network (it failed, etc.) then you can use this menu item to remove it from the interface. You might need to attempt a Define and Sync on the device (and allow it to fail) - just create a new device, try to sync it, when it fails then try to remove it.
Reset Z-Wave Interface
  • /www/perceptive/wiki/data/pages/indigo_2024.1_documentation/managing_z-wave_devices.txt
