Plugin Testing Tutorial
Testing Structure
Environment Variables
.ENV file
SECRET_CODE=zm76%g215^8sdhe
ACTION_GROUP_ID=12345678
  • /www/perceptive/wiki/data/attic/indigo_2024.1_documentation/plugin_testing_tutorial.1729259418.txt.gz
  • Last modified: 2024/10/18 13:50
