Plugin Testing Tutorial
Testing Structure
Environment Variables
.ENV file
SECRET_CODE=zm76%g215^8sdhe
ACTION_GROUP_ID=12345678
Folder Structure
While optional, it's probably best to organize your test files and keep them separate from your main plugin files. For the purposes of this tutorial, we will store them in a Tests folder of the Server Plugin. For example,
../Server Plugin
  |_ Tests
     |_ __init__.py
     |_ test_plugin.py
  • /www/perceptive/wiki/data/attic/indigo_2024.1_documentation/plugin_testing_tutorial.1729259726.txt.gz
  • Last modified: 2024/10/18 13:55
