Plugin Testing Tutorial
Testing Structure
Environment Variables
.ENV file
SECRET_CODE=zm76%g215^8sdhe
ACTION_GROUP_ID=12345678
Folder Structure
../Server Plugin
  |_ Tests
     |_ __init__.py
     |_ test_my_plugin.py
     |_ ...
Main Plugin
  • A Plugin Action Item - add a plugin action to your Actions.xml file that will be used to run the tests. It is recommended that you hide the action so it's not visible to users.
<Action id="my_tests" uiPath="hidden">
  <Name>Run All Tests</Name>
  <CallbackMethod>my_tests</CallbackMethod>
</Action>
  • A Callback Method - create a callback method in your plugin (for example, my_tests) that will be used to run your tests.
    from Tests import test_my_plugin  # your unit test file(s)
        if result[0] is True:
  • /www/perceptive/wiki/data/attic/indigo_2024.1_documentation/plugin_testing_tutorial.1729260465.txt.gz
  • Last modified: 2024/10/18 14:07
