Plugin Testing Tutorial
Python Unit Testing
Unit Testing Indigo Plugins
Testing Elements
- The
python-dotenvlibrary - used for creating and managing Python environment variables. - An IDE that supports unit testing - which not required, having an IDE that supports unit testing can be very helpful.
Testing Structure
Environment Variables
.ENV file
Folder Structure
../Server Plugin
|_ Tests
|_ __init__.py
|_ test_my_plugin.py
|_ ...
Main Plugin
if result[0] is True:
Test File Structure
This is where the bulk of your testing code will reside. You could add your tests directly to your plugin but, as mentioned above, it offers a way to segregate your testing code from your published plugin to reduce its footprint by adding them to your .gitignore file. There is, of course, wide latitude (and debate) on how to structure tests and this tutorial tries to evade all that and provide a simple example just to get you started.
Test File Structure
The test_my_plugin.py file will contain your testing code. If you're familiar with unit testing (which you should be if you're this deep in the tutorial), the structure of these tests can be as complex as you like. A simple example:
import dotenv
import indigo # noqa
import logging
import os
from unittest import TestCase
dotenv.load_dotenv()
test_case = TestCase()
class TestPlugin(TestCase):
def __init__(self):
super().__init__()
@staticmethod
return True, None
return False, error
