Plugin Testing Tutorial
Once you have developed a functioning plugin, it's a good idea to add automated methods to test your code before publishing plugins and plugin updates. “Unit testing” is considered a best practice, and Python provides built-in tools to help facilitate it. There are many ways to formulate unit tests, and this guide demonstrates one way to do it. The approach described below has advantages within the Indigo plugin framework because it allows direct access to the IOM (Indigo Object Model). It is extremely important to become familiar with the IOM and Indigo plugin development before attempting to tackle this guide.
Testing Structure
Environment Variables
.ENV file
SECRET_CODE=zm76%g215^8sdhe
ACTION_GROUP_ID=12345678
Folder Structure
../Server Plugin
  |_ Tests
     |_ __init__.py
     |_ test_my_plugin.py
     |_ ...
Main Plugin
  • A Plugin Action Item - add a plugin action to your Actions.xml file that will be used to run the tests. It is recommended that you hide the action so it's not visible to users.
<Action id="my_tests" uiPath="hidden">
  <Name>Run All Tests</Name>
  <CallbackMethod>my_tests</CallbackMethod>
</Action>
  • A Callback Method - create a callback method in your plugin (for example, my_tests) that will be used to run your tests.
    from Tests import test_my_plugin  # your unit test file(s)
        if result[0] is True:
Test File Structure
This is where the bulk of your testing code will reside. You could add your tests directly to your plugin but, as mentioned above, it offers a way to segregate your testing code from your published plugin to reduce its footprint by adding them to your .gitignore file. There is, of course, wide latitude (and debate) on how to structure tests and this tutorial tries to evade all that and provide a simple example just to get you started.
  • an init() file - to make your Tests available for module level imports.
  • one or more test files - that will contain your testing code.
Test File Structure
The test_my_plugin.py file contains your testing code. If you're familiar with unit testing (which you should be if you're this deep in the tutorial), the structure of these tests can be as complex as you like. A simple example:
import dotenv
import indigo  # noqa
import logging
import os
from unittest import TestCase
dotenv.load_dotenv()
test_case = TestCase()
class TestPlugin(TestCase):
    def __init__(self):
        super().__init__()
    @staticmethod
            return True, None
            return False, error
Running Your Tests
except Exception as error:
    indigo.server.log(f"{error}")
Even More Tests
  • testing the structure of supporting files (like a constants file), or
  • using Indigo's integrations API for remote plugin testing.
These approaches are a bit more “traditional”, can often be run directly inside an IDE and are beyond the scope of this tutorial.
  • /www/perceptive/wiki/data/attic/indigo_2024.1_documentation/plugin_testing_tutorial.1729262751.txt.gz
  • Last modified: 2024/10/18 14:45
