Airfoil Pro
Airfoil Device Types
Airfoil Instance
Adding an Instance
albumArt.png- an image of the currently playing album track if the source supports it (notably, iTunes)machineIcon.png- an icon representing the computer that is running this instance of AirfoilmechineIconAndScreenshot.png- a screenshot from the host computer with the machine icon overlayed (though this functionality seems to be missing in Airfoil versions through v5.1.0 - you just get the same image as the machine icon)sourceIcon.png- an icon representing the selected audio source in Airfoil.
States available to Scripts
| State Key | Value Type | Description |
Notes
Speaker
volume | number | The volume that the speaker is currently set to. |
Airfoil Actions
Speaker Actions
Connect Speaker
Scripting details
Action id: connect
if airfoilPlugin.isEnabled():
"connect",
deviceId=135305663, # ID of Speaker device
waitUntilDone=True
except Exception as e:
Disconnect Speaker
Scripting details
Action id: disconnect
"disconnect",
waitUntilDone=True
Toggle Speaker
Scripting details
Action id: toggle
"toggle",
waitUntilDone=True
Save Current Speaker States
Scripting details
Example 1 (no groups):
"saveCurrentSpeakerStates",
deviceId=135305663, # ID of Airfoil device
waitUntilDone=True
Example 2 (include groups):
waitUntilDone=True
Restore Saved Speaker States
Scripting details
"restoreSavedSpeakerStates",
waitUntilDone=True
Set Volume
Scripting details
Action id: setVolume
'setVolume',
props={'volume': 50},
waitUntilDone=True
Increase Volume
Scripting details
Action id: increaseVolume
'increaseVolume',
waitUntilDone=True
Example 2 (specifying delta):
'increaseVolume',
props={'volume': 15},
waitUntilDone=True
Decrease Volume
Scripting details
Action id: decreaseVolume
'increaseVolume',
waitUntilDone=True
'decreaseVolume',
waitUntilDone=True
Airfoil Instance Actions
Disconnect All Speakers
Scripting details
'disconnectAllSpeakers',
deviceId=12345678, # ID of Airfoil device
waitUntilDone=True
Change Source
Scripting details
Action id: changeSource
"changeSource",
deviceId=1346588091, # ID of Airfoil device
props=props,
waitUntilDone=True
Save Current Source
Scripting details
Action id: saveCurrentSource
"saveCurrentSource",
waitUntilDone=True
Restore Saved Source
Scripting details
Action id: restoreSavedSource
"restoreSavedSource",
waitUntilDone=True
Toggle Play/Pause
Scripting details
Action id: playPause
'playPause',
waitUntilDone=True
Next Track
Scripting details
Action id: nextTrack
'nextTrack',
waitUntilDone=True
Previous Track
Scripting details
Action id: prevTrack
'prevTrack',
waitUntilDone=True
Airfoil Scripting Actions
getSources
Action id: getSources
'getSources',
deviceId=12345678 # ID of Airfoil device
audioDevices : (list)
Item : (dict)
icon : [SNIP]
Item : (dict)
icon : [SNIP]
Item : (dict)
icon : [SNIP]
recentApplications : (list)
Item : (dict)
icon : [SNIP]
Item : (dict)
icon : [SNIP]
systemAudio : (list)
Item : (dict)
icon : [SNIP]
