Airfoil Pro
Adding an Instance
  • mechineIconAndScreenshot.png - a screenshot from the host computer with the machine icon overlayed (though this functionality seems to be missing in Airfoil versions through v5.1.0 - you just get the same image as the machine icon)
Warning: due to changes that Apple has made to their API, the Source Status Is Playing trigger will no longer fire. It will be removed in a future release.
States available to Scripts
Notes
Connect Speaker
Scripting details
Action id: connect
if airfoilPlugin.isEnabled():
            "connect",
            waitUntilDone=True
    except Exception as e:
Disconnect Speaker
Scripting details
Action id: disconnect
            "disconnect",
            waitUntilDone=True
Toggle Speaker
Scripting details
Action id: toggle
            "toggle",
            waitUntilDone=True
Save Current Speaker States
Scripting details
Example 1 (no groups):
            "saveCurrentSpeakerStates",
            waitUntilDone=True
Example 2 (include groups):
            waitUntilDone=True
Restore Saved Speaker States
Scripting details
            "restoreSavedSpeakerStates",
            waitUntilDone=True
Set Volume
Scripting details
Action id: setVolume
            'setVolume',
            props={'volume': 50},
            waitUntilDone=True
Increase Volume
Scripting details
Action id: increaseVolume
            'increaseVolume',
            waitUntilDone=True
Example 2 (specifying delta):
            'increaseVolume',
            props={'volume': 15},
            waitUntilDone=True
Decrease Volume
Scripting details
Action id: decreaseVolume
            'increaseVolume',
            waitUntilDone=True
            'decreaseVolume',
            waitUntilDone=True
Disconnect All Speakers
Scripting details
            'disconnectAllSpeakers',
            waitUntilDone=True
Change Source
Scripting details
Action id: changeSource
            "changeSource",
            props=props,
            waitUntilDone=True
Save Current Source
Scripting details
Action id: saveCurrentSource
            "saveCurrentSource",
            waitUntilDone=True
Restore Saved Source
Scripting details
Action id: restoreSavedSource
            "restoreSavedSource",
            waitUntilDone=True
Toggle Play/Pause
Scripting details
Action id: playPause
            'playPause',
            waitUntilDone=True
Next Track
Scripting details
Action id: nextTrack
            'nextTrack',
            waitUntilDone=True
Previous Track
Scripting details
Action id: prevTrack
            'prevTrack',
            waitUntilDone=True
getSources
Action id: getSources
            'getSources',
     audioDevices : (list)
          Item : (dict)
               icon : [SNIP]
          Item : (dict)
               icon : [SNIP]
          Item : (dict)
               icon : [SNIP]
     recentApplications : (list)
          Item : (dict)
               icon : [SNIP]
          Item : (dict)
               icon : [SNIP]
    systemAudio : (list)
    	  Item : (dict)
    	  	   icon : [SNIP]
  • /www/perceptive/wiki/data/attic/indigo_2024.1_documentation/plugins/airfoilpro.1734451037.txt.gz
  • Last modified: 2024/12/17 15:57
