The Indigo Reflector Service
Reflectors provide:
  • 3rd party services like Amazon Alexa can get secure, authenticated access to your Indigo Server to open up a broad range of integration possibilities.
  • Hassle free setup:
  2. Turn on the Allow remote access checkbox and enter a User name and good Password. You will *definitely* want password authentication on since you are about to enable access to the Indigo web server from the Internet.
  3. Turn on the Enable secure internet access via Indigo Reflector checkbox.
  1. Shut down the Indigo Server (select Indigo 2024.1→Stop Server) but don't quit the Indigo Client
Manual Reset
  5. In the resulting dialog, copy and paste the following: /Library/Application Support/Perceptive Automation/Indigo 2024.1/Preferences/
  • failed to create reflector connection: reflector not active - try the steps above to reset your reflector's activation
  • reflector connection test failed: local server unreachable - check this forum post for the likely causes.
  • Unable to authenticate with IndigoDomo.com (server might be down temporarily for maintenance) - you may be able to resolve the issue by:
    1. shuting down the Indigo Server,
    2. deleting the registration file located at /Library/Application Support/Perceptive Automation/Indigo 2024.1/Preferences/Indigo Registration.indiPref,
    3. restarting the Indigo Server, and
    4. when prompted, enter your Indigo Account information.
Reflectors may also be affected by a bad entry in your /etc/hosts file. Check this forum post for details.
Advanced Troubleshooting
If nothing else works, create a new topic in the reflectors forum detailing what you've tried and do the following:
1. Launch the Terminal application (inside /Applications/Utilities/)
2. Copy/paste each line below *individually* and hit the return key after each one:
id
cd /Library/Application\ Support/Perceptive\ Automation
cd Indigo\ 2024.1/IndigoServer.app/Contents/Resources/PlugIns/
ps -axww | grep "Indigo"
3. Select the entire results of the Terminal window (CMD-A) and copy/paste into Code tags (the icon that looks like this: </>).
4. Copy/paste each line below *individually* and hit the return key after each one:
./reflector_library_stub.py -m geturl -d
./reflector_library_stub.py -m tunnel -d
5. Wait 3 minutes. It can take a while for the network errors we are trying to catch to be reported. Then enter again:
6. Select the entire contents of the Terminal window (CMD-A) again and copy/paste results into another section with Code tags.
  • /www/perceptive/wiki/data/attic/indigo_2024.1_documentation/reflectors.1732131853.txt.gz
  • Last modified: 2024/11/20 19:44
  • by jay
