Apple's Shortcuts app* allows you to create custom workflows on macOS, iOS and iPadOS (you can't currently run shortcuts on tvOS). You can also use Apple Shortcuts with Indigo to call many functions and use Indigo events to fire Apple shortcuts. Using Indigo's HTTP API with Apple's Shortcuts app is easy and there are different methods to accomplish this (this document uses Indigo's v2 API).
* The shortcuts app for macOS is only available for Monterey (12.x) and newer versions. It has been available for iOS and iPadOS since version 12.</span></html>
  2. Go to Add an API Key.
IMPORTANT: in order to use API Key authentication, you MUST have enabled Enable OAuth and API Key authentication in the Indigo "Start Local Server" dialog box.
You'll need:
  • The command you want to execute – such as: indigo.device.toggle,
The Steps
  2. In the search box on the right side, type “Get Contents of URL”.
  5. Click on “Show More”.
  6. Select Method: Post.
  9. Under Key: Authorization.
  16. Under Key: objectId.
At the top of the Shortcut editor window, you can change “Get Contents of URL” to something descriptive like “Toggle Living Room Lamp”. Likewise, you can click on the icon to customize it to your taste. Finally, if you'd like, you can add the Shortcut to your dock (or home screen on iOS), a shortcuts widget, or simply fire them from within the shortcuts app.
Optional Parameters
Action Groups Shortcuts Image
Get a Variable Value
Get a Variable Value Image
  • The “trick” to getting the variable's value into the speak action is to tell your shortcut what kind of data it is. To do this, click on Get Contents of URL in the speak action, set the data type to Dictionary, and set Get Value for Key to value (be sure to hit return or tab to get the setting value to stick.)
Get Contents of URL Image
Update a Variable Value
    • key: value,
  • As with the other examples, set up your Get Contents of URL action to get a variable's value – in this example, the built-in variable isDaylight,
The example below prompts the user for text, passes the text to the script, receives the script's output, and sends that output to a macOS notification. This very basic example is simply to show how to pass input to your script and pass the script's output on to other steps. Note the use of sys.argv[1]. This statement is reading the second argument passed to the script (the first argument is its source–the shortcut itself–which we won't need). The second argument – sys.argv[1] – is passed as a string, and that's the bit we need. You'll need to account for whatever format your inputs and outputs turn out to be. These are the two most important settings to this example:
  1. Shell: Python 3
  2. Pass Input: as arguments
The rest is up to you.
  • Using a Shortcuts Widget,
  • Using Siri: “Hey Siri – Living Room Lamp” (name of the shortcut).
Location Based Shortcuts
  • Time of Day,
  • Alarm,
  • Sleep,
  • Arrive,
  • Leave,
  • Before I Commute, and
  • and many others.
  1. Review your automation.
  1. Create the shortcut using the steps outlined above using macOS or iOS. For example, you could update a variable value set to Home or Away.
  2. In the Shortcuts app for iOS (or iPadOS), select Automations from the tab at the bottom.
  3. Click the + at the top.
  4. Choose “Create Personal Automation”.
  5. Choose Arrive or Leave.
  6. On the Location setting, select Choose.
  7. Select “Current Location” or whatever location you choose, then select Done. You can also adjust the range of the trigger in the bottom map panel (the minimum range is about 100 meters or 328 feet).
  8. Select Next.
  9. Search for and select “Run Shortcut”.
  10. Next to “Run”, tap the word Shortcut and select the shortcut you created in step 1. Add any next actions as needed (not covered in this example).
  11. Select Done
Run from Indigo Action
The easiest way to run a shortcut is via an Indigo Action. Create a new Action and select Server Actions > Run Apple Script. You can optionally add text as input to the shortcut if you wish; otherwise, leave the Shortcut Input field blank.
Run Shortcut Action Image
Run from the Command Line
When calling a shortcut from the “Run Shell Script” action, it's best to use the full path to the target: %%/usr/bin/shortcuts%% to make sure Indigo can find it.
Run Shell Script Action
Run Shell Script Action Image
Run Python Script Action
os.system()
import os
Apple Shortcut
  • Calendar - Add New Event
Post Event to Calendar Image
subprocess.run()
import subprocess
External Shell Scripts
  1. Create your Notification shortcut named “Test Alert”:
  2. Create a new shortcut and add the “Show Notification” action.
  3. For Attachment, select “Shortcut Input”.
  4. Double-click “Shortcut Input” and select Type: Text
External Shell Scripts Image
#!/bin/bash
  4. Enter the full path to your script and the custom message you want to send: /Users/username/Temp/script1.sh “Hello world.” replacing /Users/username/Temp/ with the path to your script.
  6. Select Save, and then OK.
Test Alert Image
Siri Phrase Action taken
“Party Time” sets lights, temperature, tv, whatever
“Let's Party” Runs Party Time shortcut
“It's Party Time” Runs Party Time shortcut
“I'm Having a Party” Runs Party Time shortcut
Calendar
  • Create a separate calendar called “Indigo Events” to track events over time.
Clock
Home
Messages
  • With location-based automations, some (but not all) notifications can be silenced. When available, you will see a toggle for “Ask Before Running”. If you set this to off, a new toggle will appear that says, “Notify When Run”. If this is also set to off, then notifications for this automation will not be sent. Presently, there is no global setting to turn off all automation notifications.
  • Create folders in the shortcuts app that mimic the folders in Indigo. If you find that you can't drag a shortcut to a new folder, it may help to create a “dummy” shortcut into the folder first.
  • If using a local address such as localhost:8176 or 10.0.1.123:8176 make sure to use %%http://%% and not %%https://%%)
  • To use your shortcuts with Apple Watch, edit your shortcut, click on the icon and select “Show on Apple Watch”.
Command Line Commands
Command Result
shortcuts run “My Shortcut” Run shortcut named “My Shortcut”
%%shortcuts run “My Shortcut” «< '{“message”:“indigo.device.toggle”, “objectId”:“123456”, “Arg”:“Arg Value”}'%% Pass a dictionary to Indigo.
shortcuts list –f List available folders.
%%shortcuts list -f Living\ Room%% List all shortcuts in the “Living Room” folder.
Apple Documentation
  • /www/perceptive/wiki/data/attic/indigo_2024.1_documentation/shortcuts.1744661437.txt.gz
