  /Library/Application Support/Perceptive Automation/Indigo 2024.1/
  /Applications/Indigo 2024.1.app
to:
  1. Shut down the Indigo Server by selecting the Indigo 7.5→Stop Server menu item in the Mac client. This will shutdown the Indigo Server regardless of which version is running.
  2. Quit the Mac client via the Indigo 7.5→Quit Indigo menu item.
to:
  1. Shut down the Indigo Server by selecting the Indigo 7.4→Stop Server menu item in the Mac client. This will shutdown the Indigo Server regardless of which version is running.
  2. Quit the Mac client via the Indigo 7.4→Quit Indigo menu item.
to:
  1. Shut down the Indigo Server by selecting the Indigo 7.3→Stop Server menu item in the Mac client. This will shutdown the Indigo Server regardless of which version is running.
  2. Quit the Mac client via the Indigo 7.3→Quit Indigo menu item.
to:
  1. Shut down the Indigo Server by selecting the Indigo 7.2→Stop Server menu item in the Mac client. This will shutdown the Indigo Server regardless of which version is running.
  2. Quit the Mac client via the Indigo 7.2→Quit Indigo menu item.
to:
  1. Shut down the Indigo Server by selecting the Indigo 7→Stop Server menu item in the Mac client. This will shutdown the Indigo Server regardless of which version is running.
  2. Quit the Mac client via the Indigo 7→Quit Indigo menu item.
First, run the Indigo 2024.1 installer. Then look through this list for any final actions.
  • We have moved to Python v3.x, so if you installed any shared scripts (as outlined here) then you'll need to move them from: /Library/Python/X.X/site-packages/ to /Library/Python/3.11/site-packages/
  • Indigo will also copy over any enabled and disabled Plugins from Indigo 6 or 5. If a newer version of a plugin is included in Indigo, then it will automatically be installed and used on launch.
  • Your old Indigo database file will automatically be converted to the new Indigo file format on first launch. A copy of your database will automatically be made before it is converted, but any changes made in Indigo to your database will not be available in older versions of Indigo.
    • Scripts: /Library/Application Support/Perceptive Automation/Indigo 6/Scripts/
    • Control Page Images: /Library/Application Support/Perceptive Automation/Indigo 6/IndigoWebServer/images/
    • Web Server Plugins: /Library/Application Support/Perceptive Automation/Indigo 6/IndigoWebServer/plugins/
    • Scripts: /Library/Application Support/Perceptive Automation/Indigo 5/Scripts/
    • Control Page Images: /Library/Application Support/Perceptive Automation/Indigo 5/IndigoWebServer/images/
    • Web Server Plugins: /Library/Application Support/Perceptive Automation/Indigo 5/IndigoWebServer/plugins/
    • Scripts: /Library/Application Support/Perceptive Automation/Indigo 4/Scripts/
    • Control Page Images: /Library/Application Support/Perceptive Automation/Indigo 4/IndigoWebServer/images/
    • Web Server Plugins: /Library/Application Support/Perceptive Automation/Indigo 4/IndigoWebServer/plugins/
    • Scripts: /Library/Application Support/Perceptive Automation/Indigo 2/Scripts/
    • Control Page Images: /Library/Application Support/Perceptive Automation/Indigo 2/IndigoWebServer/images/
  • Your old Indigo database file will automatically be converted to the new Indigo file format on first launch. You will be prompted to save the new copy of the Indigo database file. The new Indigo file format is not compatible with Indigo 1.x. You should not replace or delete your older Indigo 1.x database file. Any changes made in Indigo to your database settings will not be available in older versions of Indigo.
NOTE: Do not replace the new Indigo versions of any file with your Indigo 1.x files. They have been modified to run optimally under the new version of Indigo.
  • /www/perceptive/wiki/data/pages/indigo_2024.1_documentation/upgrading_from_legacy_versions_of_indigo.txt
