Virtual Devices Interface
Execution Models
Automatic State Maintenance
Scripting State Maintenance
New to Indigo 2024.1 are Virtual Sensors. These plugin devices are controlled by external Python scripts that send instructions to the Virtual Device so it can track a desired status. For example, you could use an external script to send a value to the Virtual Device and then fire a trigger on the result.
Supported States
  • Status Request - your device will respond to status requests.
Script Locations
You can add scripts directly to the /Library/Application Support/Perceptive Automation/Scripts folder, or you can point to a script in any location that Indigo has the authority to access. Python scripts that are saved to the above folder will be available in the Script File dropdown menu. Alternatively, you can check the Custom Location checkbox and a field will open for you to enter the full path to the script file.
Controlling Scripts
def virtual_sensor_status():
    payload = {}
    payload['onStateValue'] = "Closed" # [string]
    payload['valueType'] = int  # the class type of the value [various]
    payload['value'] = 32  # the value must be of type listed in `valueType` above. [various]
    payload['uiValue'] = f"{payload['value']}º"  # the value in Indigo's UI. [string]
    payload['icon'] = "indigo.kStateImageSel.TemperatureSensor"  # i.e., 'sensorOn' [indigo.kStateImageSel]
    payload['error_value'] = ""  # the error value if needed; otherwise, empty string. [string]
    return payload
The Virtual Device will adjust its states based on the values returned from the virtual_sensor_status method. When that method is executed, you can make calls to other parts of your script in order to determine what the payload values should be.
Triggers and Actions
  • /www/perceptive/wiki/data/attic/indigo_2024.1_documentation/virtual_devices_interface.1723409446.txt.gz
  • Last modified: 2024/08/11 20:50
