Virtual Devices Interface
- Select
Device Groups
Sprinkler Group
Virtual On/Off Devices
Execution Models
Automatic State Maintenance
Scripting State Maintenance
Virtual Sensors
Supported States
Script Locations
You can add scripts directly to the /Library/Application Support/Perceptive Automation/Scripts folder, or you can point to a script in any location that Indigo has the authority to access. Python scripts that are saved to the above folder will be available in the Script File dropdown menu. Alternatively, you can check the Custom Location checkbox and a field will open for you to enter the full path to the script file.
Controlling Scripts
def virtual_sensor_status():
payload = {}
payload['onStateValue'] = "Closed" # [string]
payload['sensorValueType'] = int # the class type of the value [various]
payload['sensorValue'] = 32 # the value must be of type listed in `valueType` above. [various]
payload['uiValue'] = f"{payload['sensorValue']}º" # the value in Indigo's UI. [string]
payload['icon'] = "indigo.kStateImageSel.TemperatureSensor" # i.e., 'sensorOn' [indigo.kStateImageSel]
payload['error_value'] = "" # the error value if needed; otherwise, empty string. [string]
return payload
The Virtual Device will adjust its states based on the values returned from the virtual_sensor_status method. When that method is executed, you can make calls to other parts of your script in order to determine what the payload values should be.
Triggers and Actions
