Virtual Devices Interface
- Select
Device Groups
Sprinkler Group
Virtual On/Off Devices
Execution Models
Automatic State Maintenance
Scripting State Maintenance
Virtual Sensors
Supported States
Script Locations
Controlling Scripts
def virtual_sensor_status():
payload = {}
payload['onStateValue'] = "Closed" # [string]
payload['sensorValueType'] = int # the class type of the value [various]
payload['sensorValue'] = 32 # the value must be of type listed in `valueType` above. [various]
payload['uiValue'] = f"{payload['sensorValue']}º" # the value in Indigo's UI. [string]
payload['icon'] = "indigo.kStateImageSel.TemperatureSensor" # i.e., 'sensorOn' [indigo.kStateImageSel]
payload['error_value'] = "" # the error value if needed; otherwise, empty string. [string]
return payload
The Virtual Device will adjust its states based on the values returned from the virtual_sensor_status method. When that method is executed, you can make calls to other parts of your script in order to determine what the payload values should be.
Triggers and Actions
