Virtual Devices Interface
Execution Models
Automatic State Maintenance
Scripting State Maintenance
Supported States
Script Locations
Controlling Scripts
def virtual_sensor_status():
    payload = {}
    payload['sensorValueType'] = int  # the class type of the value [various]
    payload['sensorValue'] = 32  # the value must be of type listed in `valueType` above. [various]
    return payload
The Virtual Device will adjust its states based on the values returned from the virtual_sensor_status method. When that method is executed, you can make calls to other parts of your script in order to determine what the payload values should be.
Triggers and Actions
  • /www/perceptive/wiki/data/attic/indigo_2024.1_documentation/virtual_devices_interface.1726107863.txt.gz
  • Last modified: 2024/09/12 02:24
