Virtual Devices Interface
- Select
Device Groups
Sprinkler Group
Virtual On/Off Devices
Execution Models
Automatic State Maintenance
Scripting State Maintenance
Virtual Sensors
Supported States
Script Locations
Controlling Scripts
payload = {}
payload['sensorValueType'] = int # the class type of the value [various]
payload['sensorValue'] = 32 # the value must be of type listed in `valueType` above. [various]
return payload
The Virtual Device will adjust its states based on the values returned from the virtual_sensor_status method. When that method is executed, you can make calls to other parts of your script in order to determine what the payload values should be. If the update is completed successfully, the Virtual Sensor will provide a copy of the device object and an action_props dict when it requests an update from your script.
Triggers and Actions
