Virtual Devices Interface
Execution Models
Automatic State Maintenance
Scripting State Maintenance
Supported States
Script Locations
Controlling Scripts
# If you want to pass something to the Indigo Events Log, you will need to import the
import logging
    payload = {}
    payload['sensorValue'] = 32  # note that Indigo always stores this as a float [int or float]
    return payload
Triggers and Actions
  • /www/perceptive/wiki/data/attic/indigo_2024.1_documentation/virtual_devices_interface.1726138489.txt.gz
  • Last modified: 2024/09/12 10:54
