Virtual Devices Interface
Execution Models
Automatic State Maintenance
Scripting State Maintenance
Supported States
Script Locations
Controlling Scripts
# If you want to pass something to the Indigo Events Log, you will need to import the
import logging
    :device: a copy of the virtual sensor device object
    :action_props:
    payload = {}
    payload['sensorValue'] = 32  # note that Indigo always stores this as a float [int or float]
    return payload
device – in this context, the device prop will contain a copy of the Virtual Sensor device that is linked to the script. action_props – in this context, the action_props prop will contain any props passed from the Indigo Action that caused the Virtual Sensor device to update. If the device was updated by a Send Status Request or a “generic” Indigo Action refresh call, action_props will be an empty dictionary.
Triggers and Actions
  • /www/perceptive/wiki/data/attic/indigo_2024.1_documentation/virtual_devices_interface.1726139092.txt.gz
  • Last modified: 2024/09/12 11:04
