Virtual Devices Interface
- Select
Device Groups
Sprinkler Group
Virtual On/Off Devices
Execution Models
Automatic State Maintenance
Scripting State Maintenance
Virtual Sensors
Supported States
Script Locations
Controlling Scripts
# If you want to pass something to the Indigo Events Log, you will need to import the
import logging
:action_props: any action object properties provided [indigo.Dict]
payload = {}
return payload
device – in this context, the device prop will contain a copy of the Virtual Sensor device that is linked to the script.
action_props – in this context, the action_props prop will contain any props passed from the Indigo Action that caused the Virtual Sensor device to update. If the device was updated by a Send Status Request or a “generic” Indigo Action refresh call, action_props will be an empty dictionary.
Triggers and Actions
