Virtual Devices Interface
Execution Models
Automatic State Maintenance
Scripting State Maintenance
Supported States
Script Locations
Controlling Scripts
# If you want to pass something to the Indigo Events Log, you will need to import the
import logging
    :action_props: any action object properties provided [indigo.Dict]
    payload = {}
    payload['sensorValue'] = 32  # note that Indigo always stores this as a float [int or float]
    return payload
device – in this context, the device prop will contain a copy of the Virtual Sensor device that is linked to the script. action_props – in this context, the action_props prop will contain any props passed from the Indigo Action that caused the Virtual Sensor device to update. If the device was updated by a Send Status Request or a “generic” Indigo Action refresh call, action_props will be an empty dictionary.
Triggers and Actions
The indigo.actionGroup.execute API command message doesn't include action props, so the action_props property above will be an empty dict. You can execute this command message from both the Websocket and HTTP APIs.
  "objectId": 123456789
The plugin.executeAction API command message can include optional props, and is currently only available in the HTTP API command space.
    "pluginId": "com.some.indigo.plugin",   # the plugin's bundle identifier
    "actionId": "some_plugin_action",  # the ID of the plugin action found in the plugin's Actions.xml file
    "deviceId": 12345678,  # the device ID targeted by the plugin action (not all actions will require a device ID.
    "waitUntilDone": True
  • /www/perceptive/wiki/data/attic/indigo_2024.1_documentation/virtual_devices_interface.1726155386.txt.gz
  • Last modified: 2024/09/12 15:36
