Virtual Devices Interface
- Select
Device Groups
Sprinkler Group
Virtual On/Off Devices
Execution Models
Automatic State Maintenance
Scripting State Maintenance
Virtual Sensors
Supported States
Script Locations
Controlling Scripts
# If you want to pass something to the Indigo Event Log, you will need to import the
import logging
def virtual_sensor_status(device: indigo.Device, action_props: dict) -> dict:
:action_props: any action object properties provided [dict]
:returns: updated sensor values [dict]
payload = dict()
return payload
device – in this context, the device parameter will contain a copy of the Virtual Sensor device that is linked to the script.
action_props – in this context, the action_props parameter will contain any props passed from the Indigo Action that caused the Virtual Sensor device to update. If the device was updated by a Send Status Request or a “generic” Indigo Action refresh call, action_props will be an empty dictionary.
Triggers and Actions
The indigo.actionGroup.execute API command message doesn't include action props, so the action_props property above will be an empty dict. You can execute this command message from both the Websocket and HTTP APIs.
"objectId": 123456789
The plugin.executeAction API command message can include optional props, and is currently only available in the HTTP API command space.
"actionId": "some_plugin_action", # the ID of the plugin action found in the plugin's Actions.xml file
"deviceId": 12345678, # the device ID targeted by the plugin action (not all actions will require a device ID.
"waitUntilDone": True
