Indigo Object Model Reference
# some code here
# that does something
TermMeaning
Trigger An action (or collection of actions) that will executed based on some input event - a device state change, an event from a plugin, an email received, etc. When the event occurs, IndigoServer evaluates any conditions specified in the trigger in order to decide if the actions associated with the event should execute.
For Scripters and Developers:
For Developers:
ClassCommand namespaceNotes
Schedule
Triggers
DeviceStateChangeTrigger (indigo.DeviceStateChangeTrigger)indigo.devStateChange.*manipulate a device state change trigger
Variables
Protocol Specific Commands
General Commands
There are a few classes that are special. One is Action and it’s subclasses (collectively referred to as “actions”). Why are these classes different? Because outside of the trigger, schedule, action group, or control page that they’re associated with they aren’t individually addressable in the IndigoServer: for instance, there is no way to identify an action without first identifying the trigger that it’s associated with.
All commands in the IOM accept the id of an object or the object reference itself (along with the name). You should never store the object’s name. The id is visible in the various lists throughout the UI. You can also select any object in the GUI and right click it to get it’s contextual menu where you'll find a Copy ID (123) item that shows the ID and allows you to copy it to the clipboard. Server plugins that define config UIs that use the built-in lists will get the id(s) of the object(s) selected in the lists rather than the name.
  • keys cannot contain spaces.
c = indigo.List()
c.append(4)
c.append(5)
c.append(True)
c.append(False)
a = indigo.Dict()
a['a'] = "the letter a"
a['b'] = False
print(str(a))
c.append(6)
a['c'].append(6)
a['c'] = c
print(str(a))
Object Description
Object Events
Objects that support subscribeTochanges()
Lower-level Events
Low Level Commands (Insteon and x10 Only)
indigo.x10.subscribeToIncoming()
indigo.x10.subscribeToOutgoing()
        if cmd.cmdType == "sec":    # or "x10" for power line commands
            if cmd.secCodeId == 6:
Iterating Object Lists
for dev in indigo.devices:
    # do stuff with dev here
Filter Description
indigo.x10include X10 devices
indigo.dimmerdimmer devices
indigo.sprinklersprinklers
indigo.thermostatthermostats
Triggers also have filters:
Filter Description
for var in indigo.variables:
    # all variables
Possible Exceptions
PluginNotFoundError a plugin that you're trying to talk to (on a create() perhaps) isn't avaliable (disabled or gone)
>>> dev.__class__
<class 'indigo.DimmerDevice'>
>>> hasattr(dev,'onState')
True
>>> dir(dev)
>>> thermo.__class__
>>> dir(thermo)
>>> tunes.__class__
<class 'indigo.Device'>
>>> dir(tunes)
>>> tunes.deviceTypeId
u'mediaserver'
So, from a discovery perspective, the dir(obj) method will list all properties and methods for an object. The hasattr(obj, attr) will test an object to see if it has a specific attribute. The obj.__class__ attribute will show you what class the object is. As you explore IOM objects, these methods will help you figure out how to use IOM objects effectively.
>>> dev = indigo.devices[123]
address :
batteryLevel : None
buttonGroupCount : 0
configured : True
description :
<'indigo.Device'>
>>> dev_dict = dict(dev)
<class 'dict'>
Name Base Description
FileNotFoundErrorException This is a useful exception if you handle files in any way. There is no built-in processing to catch such exceptions, it's just a useful exception to use.
IndigoJSONEncoderJSONEncoder Use this encoder class if you are encoding a python date, time, or datetime class into a JSON string. Very useful if you attempt to encode a device dictionary into JSON (json.dumps(dict(mydevice), cls=indigo.utils.IndigoJSONEncoder))
Return Static File
status No int the HTTP status code to return, defaults to 200
path_is_relative No boolean is the path a full path or relative to the plugin, defaults to True
content_type No string a string to return as the mime type of the content, returns the appropriate type based on the file extension if none is specified
    "status": 404,
    "headers": {
        "Content-Type": "text/html"
    "file_path": "/Library/Application Support/Perceptive Automation/Indigo 2024.1/Plugins/Example HTTP Responder.indigoPlugin/Contents/Resources/static/html/static_404.html"
Validate Email Address
indigo.utils.validate_email_address("valid_email@someserver.com")
  • /www/perceptive/wiki/data/pages/indigo_2024.1_documentation/object_model_reference.txt
