apiVersion string No API v1.7: the currently connected Indigo Server plugin API version as a string (ex: “1.7”)
connectionGood boolean No true if the connection to the Indigo Server is currently good
portNum integer No the port number of the currently connected Indigo Server
License Status Enumeration
Value Description
ActiveSubscription license has an active Indigo Up-to-Date subscription (access to a reflector)
showTimeStamp No boolean indicate whether every line should have it’s timestamp prepended to the log entry - the default is true
Returns the server's list of elements that have attributes orproperties that are now deprecated.
lat = latLong[0]
long = latLong[1]
for posixPath in ports:
	print(posixPath)
	print(uiName)
# iterate through both
	print(posixPath)
	print(uiName)
indigo.server.getTime()
No Parameters
  1. Reflector (https://reflector.indigodomo.net) if a reflector is configured.
  2. Bonjour name (http://MacName.local:PORT) if it can be determined.
  3. Localhost (http://localhost:PORT) if all else fails.
No Parameters
Tell the server to shutdown our plugin process. Plugin will remain enabled but be in a stopped state. This command can only be called from a plugin and it refers to the plugin itself (not all plugins).
indigo.server.subscribeToLogBroadcasts()
indigo.server.waitUntilIdle()
  • /www/perceptive/wiki/data/pages/indigo_2024.1_documentation/server_commands.txt
