Indigo Web Server
Security Certificates
Select the Indigo 2024.2→Advanced Web Server Settings… menu item and you'll get this dialog:
The menu has three options:
/Library/Application Support/Perceptive Automation/Indigo 2024.1/Web Assets/images
/Library/Application Support/Perceptive Automation/Indigo 2024.1/Web Assets/plugins
/Library/Application Support/Perceptive Automation/Indigo 2024.1/Web Assets/public
/Library/Application Support/Perceptive Automation/Indigo 2024.1/Web Assets/static
images folder
plugins folder
public folder
For example:
static folder
For example:
Authentication
API Keys
Local Secrets
    "here-is-a-key",
    "this*is*another*key"
    "here-is-a-key",
    "this*is*another*key",
    "do-not-use-api-keys"
Custom Web Page Example
<!DOCTYPE html>
<html lang="en">
  <head>
    <meta charset="utf-8">
  </head>
      Hello world.
    </div>
  </body>
</html>
  • /www/perceptive/wiki/data/attic/indigo_2024.2_documentation/indigo_web_server.1743564487.txt.gz
  • Last modified: 2025/04/02 03:28
  • by jay
