Managing Your Z-Wave® Network
Connecting Z-Wave Interfaces
- Choose the
Configure Z-Wavedialog.
Adding a Z-Wave Device
- Select
Using Encryption
- Select
Resyncing a Z-Wave Device
- Select
Edit…button). - Click the
Syncbutton. - When the
Replacing a Z-Wave Device
- Select
- When the
Excluding a Z-Wave Device
From time to time, you may find the need to exclude a device from your Z-Wave network. For example:
- you want to factory reset it (resetting doesn't necessarily require a device to be excluded from the network),
- replace a device with a newer device, or
- add a device to your setup that was previously included in another controller.
There are some important points to remember about device exclusion:
- Excluding a device from the controller releases the device from the controller and allows it to be used with another controller.
- If your controller has failed and you want to add your device to a new controller, you can perform the exclusion with your new controller (essentially any controller can exclude a device–even if the device was included with a different controller).
- Just because you've excluded a device from the network, doesn't mean that all the other devices that used to talk to it know it's gone. That's why it's always a good idea to optimize your network after making big changes (adding or removing many devices or changing the location of many devices or the controller).
You can usually preserve your Indigo setup when excluding a device. The Indigo device object and all the things that refer to it are independent of the physical device itself. Simply exclude the first device, include the second one and then point your Indigo device definition to the new device. It will be shown in the Sync using node dropdown as an Available Node ID:
This assumes that you're replacing a device with one that is of a similar type.
To exclude a device:
- Depending on your device, you may need to bring the device into close proximity with the controller. Alternatively, if your controller supports it, you can take your controller to the device.
- Select the
Interfaces→Start Controller Exclusion Mode. - Following your device's instructions, initiate an exclude action (different devices may require different steps).
- If the exclusion has been done successfully, Indigo will automatically exit the exclusion and the device should no longer appear in the Z-Wave device list.
Deleting a Z-Wave Device
- Select
- Click the
Replacing a Z-Wave Controller
If your controller doesn't have a physical inclusion button you must follow this process. You may also use this process even if your controller does have a button (such as the Aeotec Z-Stick) as it's the more “universal” approach:
- Select the
- Finally, select the
Z-Wave Menu Options
Manage Associations
Send Raw Z-Wave Command
Stop Inclusion / Exclusion
Report Failed Modules to Event Log
This menu item will write any devices that the Z-Wave interface believes may have failed to the Indigo Events Log. This list is managed by the Z-Wave interface (not by Indigo) and it's important to note that the listed devices may not have actually failed (the interface may list a device that it hasn't received a transmission from for a while, for example). It's recommended that you use this menu item from time to time to ensure that the interface has the correct information for your devices.
January 1, 1970 at 12:34:56 AM Z-Wave found failed module reported by controller "028 - Energy Meter Device" Z-Wave found failed module reported by controller "042 - Dehumidifier"
If you see a device listed that you believe should not be listed, it is often enough to simply browse to that device in the Indigo UI, open the Edit Device dialog, and perform a Define and Sync operation. Indigo will attempt to refresh the device's information and, if successful, tell the Z-Wave interface to remove the device from the failed devices list. After performing this operation, you can confirm the device has been removed from the list by rerunning the Report Failed Modules to Event Log step.
If the interface doesn't think that any devices are in a failed state, running the report will result in
Z-Wave no failed modules found in controller
If a Z-Wave device has failed or is no longer available to your network, you can use this menu item to remove it from the Z-Wave interface.
You may have to attempt to resync the device in order for it to be listed as failed.
- If an Indigo device object still exists, you can open the Edit Device dialog and attempt to Defne and Sync the device. If it has truly failed, the sync operation will fail, and Indigo will tell the Z_Wave interface to report the device has failed.
- If an Indigo device object is no longer available, you can simply create a new device, attempt to add the failed device and, when the operation has failed, Indigo will tell the Z-Wave interface to report the device has failed.
If you select this menu item and the Z-Wave interface doesn't have any failed devices in its list, Indigo will return this message:
Reset Z-Wave Interface
