SQL Logger Plugin
- Download a PostgreSQL installer. Note there are other installers available elsewhere as well.
- Add the path to the PostgreSQL binary to your bash profile file. From the Terminal copy/paste:
- Next, open the System Preferences and choose the PostgreSQL Server icon that was added. You should now be able to start the server. Note the some installers seem to included a Server Manage.app application, but they may not work correctly. However, the panel in the System Preferences does appear to work.
- From the command line you can now try to connect to the server via:
psql -U postgres
- Next, select the
Plugins→SQL Logger→Configure…menu item, then selectPostgreSQLas the database type.
By default Indigo will connect to the PostgreSQL server running on the same Mac (127.0.0.1) using the default PostgreSQL username of postgres, and will automatically create a new database named indigo_history. Your PostgreSQL install might also support local connections directly using the host name /var/pgsql_socket/.s.PGSQL.5432.
Logging Options
Database Table Format
and
| ts | value |
Example Queries
PostgreSQL Queries
SQLite Queries
Events
Aug 9, 2012 3:38:10 AM My Type Error this is an error from a script NOAA Weather Plus Error Error parsing XML from NOAA for device Weather Forecast: not well-formed (invalid token): line 1, column 111
Scripting Support
Support and Troubleshooting
