The Indigo Reflector Service
About Reflectors
Reflectors provide:
- Hassle free setup:
Activating your Reflector
- Choose the
Allow remote accesscheckbox and enter a User name and good Password. You will *definitely* want password authentication on since you are about to enable access to the Indigo web server from the Internet. - Turn on the
Enable secure internet access via Indigo Reflectorcheckbox. - Press the
Activate Reflectorbutton.
Indigo 2024.2→Stop Server) but don't quit the Indigo Client - Switch to your browser and log out of your Indigo Account
Start Local Serverbutton
Manual Reset
/Library/Application Support/Perceptive Automation/Indigo 2024.2/Preferences/ - In the resulting Finder window, delete the folder named
Bandwidth Limits
Troubleshooting
- failed to create reflector connection: reflector not active - try the steps above to reset your reflector's activation
- reflector connection test failed: local server unreachable - check this forum post for the likely causes.
- Unable to authenticate with IndigoDomo.com (server might be down temporarily for maintenance) - you may be able to resolve the issue by:
- shutting down the Indigo Server,
- deleting the registration file located at
/Library/Application Support/Perceptive Automation/Indigo 2024.2/Preferences/Indigo Registration.indiPref, - restarting the Indigo Server, and
- when prompted, enter your Indigo Account information.
Reflectors may also be affected by a bad entry in your /etc/hosts file. Check this forum post for details.
Advanced Troubleshooting
If nothing else works or if directed by Indigo support, create a new topic in the reflectors forum detailing what you've tried and do the following:
1. Launch the Terminal application (inside /Applications/Utilities/)
2. Copy/paste each line below *individually* and hit the return key after each one:
id cd /Library/Application\ Support/Perceptive\ Automation cd Indigo\ 2024.2/IndigoServer.app/Contents/Resources/PlugIns/ ps -axww | grep "Indigo"
3. Select the entire results of the Terminal window (CMD-A) and copy/paste into Code tags (the icon that looks like this: </>).
4. Copy/paste each line below *individually* into the Terminal window and hit the return key after each one:
./reflector_library_stub.py -m geturl -d ./reflector_library_stub.py -m tunnel -d
5. Wait 3 minutes. It can take a while for the network errors we are trying to catch to be reported. Then enter again:
6. Select the entire contents of the Terminal window (CMD-A) again and copy/paste results into another section with Code tags.
