Using Apple Shortcuts with Indigo
WARNING: Unfortunately, it looks like Apple broke the shortcuts command line tool (which we use to run shortcuts) in Sonoma 14.7.5. If you rely on shortcuts in Indigo you'll probably want to skip that release. We tested on Sequoia 15.3.1 and it works correctly.
Apple's Shortcuts app* allows you to create custom workflows on macOS, iOS and iPadOS (you can't currently run shortcuts on tvOS). You can also use Apple Shortcuts with Indigo to call many functions and use Indigo events to fire Apple shortcuts. Using Indigo's HTTP API with Apple's Shortcuts app is easy and there are different methods to accomplish this (this document uses Indigo's v2 API).
* The shortcuts app for macOS is only available for Monterey (12.x) and newer versions. It has been available for iOS and iPadOS since version 12.</span></html>
Obtaining an API Key
- Log into your Indigo account's Authorizations Page.
- Go to
Add an API Key. - Select the Server that you want to use to accept the key.
- Click on the
Add API Keybutton.
IMPORTANT: in order to use API Key authentication, you MUST have enabled Enable OAuth and API Key authentication in the Indigo "Start Local Server" dialog box.
Building Your First Shortcut
You'll need:
- The base URL:
https://MY-REFLECTOR-NAME.indigodomo.net/v2/api/command/(replaceMY-REFLECTOR-NAMEwith the name of your active reflector, - Your authentication key:
c2xr7q35-9385-10f9-3652-12z765j99vnv(replace with your valid key. This one is fake.), - The command you want to execute – such as:
indigo.device.toggle, - The Indigo ID of the device (or action, or variable, etc.) you want the command to apply to:
123456, and - Any parameters you want to include (some are optional, some are required.)
The Steps
- New shortcut (
+at the top) - In the search box on the right side, type “Get Contents of URL”.
- Drag (or double-click) the action to add it to the editor.
- Click on the
URLfield and enter the base URL above. If using an external IP address or reflector make sure to usehttps:and not justhttp:. - Click on “Show More”.
- Select Method:
Post. - Expand the Headers section by clicking on the
>. - Within the Headers section, click the
+. - Under Key:
Authorization. - Under Value:
Bearer 2x7a35-9385-10f9-3652-12765:99vnv. (The wordBearer, one space and then your API key.) - Make sure that
Request Bodyis set toJSON. - Within the Request Body section, click the
+. - Under Key:
message(make sure theTypeis set toText. - Under Value:
indigo.device.toggle. - Within the Request Body section, click the
+. - Under Key:
objectId. - Under Value:
123456(your device ID, make sure theTypeis set toNumber.)
At the top of the Shortcut editor window, you can change “Get Contents of URL” to something descriptive like “Toggle Living Room Lamp”. Likewise, you can click on the icon to customize it to your taste. Finally, if you'd like, you can add the Shortcut to your dock (or home screen on iOS), a shortcuts widget, or simply fire them from within the shortcuts app.
Optional Parameters
Action Group Shortcuts
- The command:
indigo.actionGroup.execute(Text) - The Action ID: 123456 (Number)
Variable Shortcuts
Get a Variable Value
- You can get an individual variable object by referencing its Indigo ID directly
%%https://MY-REFLECTOR-NAME.indigodomo.net/v2/api/indigo.variables/MY-VAR-ID%%where you replaceMY-REFLECTOR-NAMEwith your active reflector name andMY-VAR-IDwith your variable's ID.
- The “trick” to getting the variable's value into the
speakaction is to tell your shortcut what kind of data it is. To do this, click onGet Contents of URLin the speak action, set the data type toDictionary, and setGet Value for Keytovalue(be sure to hit return or tab to get the settingvalueto stick.)
Update a Variable Value
- The command:
indigo.variable.updateValue(Text) - The Action ID: 123456 (Number)
- A parameters dictionary that has one key/value pair (required):
key: value,- the new variable value which must be set to Text because all Indigo variable values are stored as text.
- As with the other examples, set up your
Get Contents of URLaction to get a variable's value – in this example, the built-in variableisDaylight, - Take the returned dictionary and extract the value of the
isDaylightvariable in aTextaction, - Add an
Ifcondition and, if the Text value is equal tofalse(Indigo variable values are always strings/text) then run your next shortcut action. Alternatively, you could send another command directly to the Indigo server (which is essentially what your linked shortcut is doing). - If the Text value is not
false, theOtherwiseaction will be executed.
Running an External Python Script
The example below prompts the user for text, passes the text to the script, receives the script's output, and sends that output to a macOS notification. This very basic example is simply to show how to pass input to your script and pass the script's output on to other steps. Note the use of sys.argv[1]. This statement is reading the second argument passed to the script (the first argument is its source–the shortcut itself–which we won't need). The second argument – sys.argv[1] – is passed as a string, and that's the bit we need. You'll need to account for whatever format your inputs and outputs turn out to be. These are the two most important settings to this example:
- Shell:
Python 3 - Pass Input:
as arguments
The rest is up to you.
Using Your Shortcuts
- Save shortcuts to your Home Screen in iOS (using the Share menu),
- Using a Shortcuts Widget,
- Create a folder of your shortcuts on iOS to mimic a widget,
- Add shortcuts to the Dock in macOS (File menu),
- Using Siri: “Hey Siri – Living Room Lamp” (name of the shortcut).
Location Based Shortcuts
- Time of Day,
- Alarm,
- Sleep,
- Arrive,
- Leave,
- Before I Commute, and
- and many others.
- Review your automation.
- Create the shortcut using the steps outlined above using macOS or iOS. For example, you could update a variable value set to
HomeorAway. - In the Shortcuts app for iOS (or iPadOS), select
Automationsfrom the tab at the bottom. - Click the
+at the top. - Choose “Create Personal Automation”.
- Choose
ArriveorLeave. - On the Location setting, select
Choose. - Select “Current Location” or whatever location you choose, then select
Done. You can also adjust the range of the trigger in the bottom map panel (the minimum range is about 100 meters or 328 feet). - Select
Next. - Search for and select “Run Shortcut”.
- Next to “Run”, tap the word
Shortcutand select the shortcut you created in step 1. Add any next actions as needed (not covered in this example). - Select
Done
Firing Shortcuts From Indigo
Run from Indigo Action
The easiest way to run a shortcut is via an Indigo Action. Create a new Action and select Server Actions > Run Apple Script. You can optionally add text as input to the shortcut if you wish; otherwise, leave the Shortcut Input field blank.
Run from the Command Line
When calling a shortcut from the “Run Shell Script” action, it's best to use the full path to the target: %%/usr/bin/shortcuts%% to make sure Indigo can find it.
Run Shell Script Action
- Run the shortcut using a Run Shell Script Action.
- Configure the shortcut to request the text value from Indigo using the appropriate API method outlined above.
Run Python Script Action
os.system()
Apple Shortcut
- Get Text From - Shortcut Input
- Calendar - Add New Event
subprocess.run()
External Shell Scripts
- Create your Notification shortcut named “Test Alert”:
- Create a new shortcut and add the “Show Notification” action.
- For
Attachment, select “Shortcut Input”. - Double-click “Shortcut Input” and select Type:
Text
chmod +x script1.sh and hit return. Now we can run our shell script from Indigo.
- Under Actions, create a new Action (or add a new Action to an existing Action Group.
- Select Type:
Run Shell Script. - Select
Edit Action Settings. - Enter the full path to your script and the custom message you want to send:
/Users/username/Temp/script1.sh “Hello world.”replacing/Users/username/Temp/with the path to your script. - If you like, you can elect to have the result saved to an Indigo Variable (optional).
- Select
Save, and thenOK.
Firing Your Shortcuts with Siri
| Siri Phrase | Action taken |
| “Party Time” | sets lights, temperature, tv, whatever |
| “Let's Party” | Runs Party Time shortcut |
| “It's Party Time” | Runs Party Time shortcut |
| “I'm Having a Party” | Runs Party Time shortcut |
Ideas
Calendar
- Create a separate calendar called “Indigo Events” to track events over time.
- Add weather information to your Calendar.
Clock
- Create an alarm on your phone.
Home
- Use Indigo to trigger events with your HomeKit devices.
- Use HomeKit to trigger events with your Indigo server.
Messages
- Send messages with important information about your Indigo server.
- Trigger your Indigo server by texting a phrase.
Tips
- If you save your shortcuts to the Home Screen in iOS, be sure you're happy with the look of the icons before you add a bunch of them. Changes you make to the icons later in the Shortcuts app won't update home screen bookmarks automatically (they will change automatically in widgets).
- Put your most commonly used shortcuts first because widgets only display a few at a time.
- You can create shortcuts in the iOS app, but it is much easier to create them in macOS.
- With location-based automations, some (but not all) notifications can be silenced. When available, you will see a toggle for “Ask Before Running”. If you set this to
off, a new toggle will appear that says, “Notify When Run”. If this is also set tooff, then notifications for this automation will not be sent. Presently, there is no global setting to turn off all automation notifications. - Create folders in the shortcuts app that mimic the folders in Indigo. If you find that you can't drag a shortcut to a new folder, it may help to create a “dummy” shortcut into the folder first.
- If using a local address such as
localhost:8176or10.0.1.123:8176make sure to use%%http://%%and not%%https://%%) - To use your shortcuts with Apple Watch, edit your shortcut, click on the ⓘ icon and select “Show on Apple Watch”.
- Indigo servers running versions of macOS prior to Monterey do not have local access to the Shortcuts app.
Reference
Command Line Commands
| Command | Result |
%%shortcuts run “My Shortcut” «< '{“message”:“indigo.device.toggle”, “objectId”:“123456”, “Arg”:“Arg Value”}'%% | Pass a dictionary to Indigo. |
%%shortcuts list -f Living\ Room%% | List all shortcuts in the “Living Room” folder. |
