Virtual Devices Interface
Execution Models
Automatic State Maintenance
Scripting State Maintenance
New to Indigo 2024.2 are Virtual Sensors. These plugin devices are linked to external Python scripts that send instructions to the Virtual Device so it can be used to track a desired status. The device also sends information back to the external script for further processing if needed.
Virtual Sensor Configuration Dialog Image
Supported States
Script Locations
Controlling Scripts
# If you want to pass something to the Indigo Event Log, you will need to import the
import logging
def virtual_sensor_status(device: indigo.Device, action_props: dict) -> dict:
    :action_props: any action object properties provided [dict]
    :returns: updated sensor values [dict]
    payload = dict()
    payload['sensorValue'] = 32  # note that Indigo always stores this as a float [int or float]
    return payload
device – in this context, the device parameter will contain a copy of the Virtual Sensor device that is linked to the script. action_props – in this context, the action_props parameter will contain any props passed from the Indigo Action that caused the Virtual Sensor device to update. If the device was updated by a Send Status Request or a “generic” Indigo Action refresh call, action_props will be an empty dictionary.
Triggers and Actions
The indigo.actionGroup.execute API command message doesn't include action props, so the action_props property above will be an empty dict. You can execute this command message from both the Websocket and HTTP APIs.
  "objectId": 123456789
The plugin.executeAction API command message can include optional props, and is currently only available in the HTTP API command space.
    "pluginId": "com.some.indigo.plugin",   # the plugin's bundle identifier
    "actionId": "some_plugin_action",  # the ID of the plugin action found in the plugin's Actions.xml file
    "deviceId": 12345678,  # the device ID targeted by the plugin action (not all actions will require a device ID.
    "waitUntilDone": True
  • /www/perceptive/wiki/data/pages/indigo_2024.2_documentation/virtual_devices_interface.txt
