Events Data Passing
- server - this is what will show if the server performed the event on it's own during the normal course of operations. A device state change trigger, a schedule fires, etc.
- python - this is what the source would be if the operation was started via an IOM command. So if you did a indigo.actionGroup.execute(12345) this is what the source would be.
- api-http - similar to python above, but if the command came in through the HTTP API.
- api-websocket - similar to api-http, but the command would have come through a websocket.
"event-plugin-event-id": "zwaveCommand", # ID of the plugin supplied event
"event-plugin-id": "com.perceptiveautomation.indigoplugin.zwave", # plugin id
"event-plugin-name": "Z-Wave", # plugin name
How do you pass data through?
- You won't want to duplicate any of the above built-in names as it would get overwritten. - You probably want to name your keys with something that's easily identified with your plugin. For instance, the Z-Wave plugin uses the prefix `zwavecmd-` for it's keys that describe the event data that it passes through. - We tried to use dashes `-` as separators rather than underscores - we think that's a better option for string keys. - Keys should follow the restrictions on `indigo.Dict` keys (alphanumeric, dash, underscore, starting with a letter).
How will users use the data?
# here.
pass
action: any,
dev: any,
Examples of how it may be used
There are likely a lot of different scenarios where event_data is useful. One thing that comes to mind almost immediately would be for plugins that provide virtual devices/wrappers/shims to allow the user to specify a path in the data then map that into either a custom state or a property (onState, etc). Combine this functionality with the Webhook functionality and it would make it possible to have a webhook directly update a virtual device. This would reduce a lot of glue code necessary now in handling those types of things.
