Path Specifiers
Path specifiers use a specific syntax and require knowledge about the event data you'll be receiving from the event. For example, given this Indigo event data:
"foo": 1234567890,
"bar": "Baz",
"data": ["Thing 1", "Thing 2"], # a list
"more_data": {'a': 1, 'b': 2}, # a dictionary
"bar" equals "Baz"
"data" equals ["Thing 1", "Thing 2"]
"more_data['b'] equals {'a': 1, 'b': 2}
So setting the path specifier to one of the above, would reference/access the corresponding value shown. If you want to go deeper into the payload, specifiers can be chained together like this:
"foo": 1234567890,
"bar": "Baz",
"data": [
"Thing 1",
"Thing A",
"Thing B",
"Thing C"
"more_data": {
"a": 1,
"b": 2,
"c": [
1,
2,
3,
4,
5
"data[0]" equals "Thing 1" # The index of the list element, the index starts at zero "data[1][2]" equals "Thing C" # The second element (index 1) of "data" is a list and the third element (index 2) of that list is "Thing C" "more_data.a" equals 1 # The value of key "a" is 1 "more_data.c[3] equals 4 # The value of key "c" is a list and the fourth element (index 3) of that list is 4
