Path specifiers use a specific syntax and require knowledge about the event data you'll be receiving from the event. For example, given this Indigo event data:
    "foo": 1234567890,
    "bar": "Baz",
  • bar equals “Baz”
  • data equals [“Thing 1”, “Thing 2”]
  • more_data['b'] equals {'a': 1, 'b': 2}
So setting the path specifier to one of the above, would reference/access the corresponding value shown. If you want to go deeper into the payload, specifiers can be chained together like this:
    "foo": 1234567890,
    "bar": "Baz",
    "data": [
        "Thing 1",
            "Thing A",
            "Thing B",
            "Thing C"
    "more_data": {
        "a": 1,
        "b": 2,
        "c": [
            1,
            2,
            3,
            4,
            5
  • data[0] equals “Thing 1” # The index of the list element, the index starts at zero
  • data[1][2] equals “Thing C” # The second element (index 1) of “data” is a list and the third element (index 2) of that list is “Thing C”
  • more_data.a equals 1 # The value of key “a” is 1
  • more_data.c[3] equals 4 # The value of key “c” is a list and the fourth element (index 3) of that list is 4
  • /www/perceptive/wiki/data/attic/indigo_2025.1_documentation/events_data_path_specifiers.1761085585.txt.gz
  • Last modified: 2025/10/21 22:26
