Path specifiers use a specific syntax and require knowledge about the event data you'll be receiving from the event. For example, given this Indigo event data:
    "foo": 1234567890,
    "bar": "Baz",
You could use path specifiers like these to retrieve the associated data:
Specifier Result
bar “Baz”
data [“Thing 1”, “Thing 2”]
more_data['b'] 2
If you want to go deeper into the payload, specifiers can be chained together like this:
    "foo": 1234567890,
    "bar": "Baz",
    "data": [
        "Thing 1",
            "Thing A",
            "Thing B",
            "Thing C"
    "more_data": {
        "a": 1,
        "b": 2,
        "c": [
            1,
            2,
            3,
            4,
            5
You can go deeper like this:
Specifier Result
data[0] “Thing 1” (The index of the list element, the index starts at zero)
data[1][2] “Thing C” # The second element (index 1) of “data” is a list and the third element (index 2) of that list is “Thing C”
more_data.a 1 # The value of key “a” is 1
more_data.c[3] 4 # The value of key “c” is a list and the fourth element (index 3) of that list is 4
  • /www/perceptive/wiki/data/attic/indigo_2025.1_documentation/events_data_path_specifiers.1761086106.txt.gz
  • Last modified: 2025/10/21 22:35
