Path Strings
"foo": 1234567890,
"bar": "Baz",
"data": ["Thing 1", "Thing 2"], # a list
"more_data": {'a': 1, 'b': 2}, # a dictionary
| Path String | Result |
bar | “Baz” |
data | [“Thing 1”, “Thing 2”] |
more_data['b'] | 2 |
If you want to go deeper into the payload, path strings can be chained together like this:
"foo": 1234567890,
"bar": "Baz",
"data": [
"Thing 1",
"Thing A",
"Thing B",
"Thing C"
"more_data": {
"a": 1,
"b": 2,
"c": [
1,
2,
3,
4,
5
You can go deeper like this:
data[0] | “Thing 1” (The index of the list element, the index starts at zero) |
data[1][2] | “Thing C” # The second element (index 1) of “data” is a list and the third element (index 2) of that list is “Thing C” |
more_data.a | 1 # The value of key “a” is 1 |
more_data.c[3] | 4 # The value of key “c” is a list and the fourth element (index 3) of that list is 4 |
You can chain these path strings as needed, such as some_json[3].a.foo[9]. NOTE: if a path string is not provided, Indigo will return the entire payload. Any path that includes a collection (like the lists and dicts above), Indigo will convert it to JSON and respond with that data.
Indigo-supplied Event Data
"_comment": "This is what you get when you execute an action group from the http api",
"event-indigo-id": 1893263747,
"event-type": "ActionGroup",
"source": "api-http",
"timestamp": "2025-10-16T14:59:05",
"unique-id": "1dd66fc1-ce8c-43f7-996f-5b29278c1b90"
"_comment": "When a webhook is called with a JSON dictionary (in data param)",
"data": {
"id": "ShortcutWithJsonInputTests.test_webhook_json_input_var_output",
"message": "something-happened",
"some-data": {
"some-key": [
"some-value",
"some-other-value"
"unique-id": "9d34e21b-9926-4023-ab94-c0cc52ecedd5"
"event-indigo-id": 879507411,
"event-plugin-event-id": "simpleWebhook",
"event-plugin-id": "com.indigodomo.webserver",
"event-plugin-name": "Web Server",
"http-method": "POST",
"http-post-content": "JSON",
"request-url": "https://localhost:8176/webhook/shortcut-json-input-var-output",
"source": "python",
"status-code": 200,
"timestamp": "2025-10-16T14:58:55",
"webhook-id": "shortcut-json-input-var-output"
Control Page Clicks
"client-ip": "127.0.0.1",
"client-is-private": true,
"control-id": 0,
"event-indigo-id": 120091806,
"event-type": "ControlPage",
"timestamp": "2025-10-16T16:10:54"
Device State Change Trigger
If a device state has any change.
"_comment": "When the server executes a has any change device state change trigge"
"change-type": "any change",
"change-type-iom": "indigo.kStateChange.Changes",
"device-id": 1167180255,
"event-indigo-id": 625370601,
"event-type": "DeviceStateChangeTrigger",
"new-value": "on",
"old-value": "off",
"source": "server",
"state-key": "onOffState",
"timestamp": "2025-10-16T17:07:23"
Insteon Command Received
"_comment": "when any insteon command is received",
"event-indigo-id": 1086420814,
"event-type": "InsteonCommandReceivedTrigger",
"insteon-cmd-rcvd": {
"Address": 1652724,
"AddressStr": "19.37.F4",
"CommandDetails": 0,
"CommandName": "on",
"CommandVal": 0,
"GroupBroadcastNum": 1,
"IsGroupBroadcast": true,
"SendCleanups": false
"source": "server",
"timestamp": "2025-09-24T15:00:12"
"_comment": "when a double-tap off command is received"
"event-indigo-id": 1398699236,
"Address": 1652724,
"CommandName": "off (instant)",
"CommandVal": 0,
"source": "server",
"timestamp": "2025-08-12T17:39:49"
Server Executed Schedules
When the server executes a schedule during normal operation.
"event-indigo-id": 485722026,
"event-type": "Schedule",
"source": "server",
"timestamp": "2025-10-16T13:55:02"
Variable Changes
"change-type": "becomes equal",
"change-type-iom": "indigo.kVarChange.BecomesEqual",
"event-indigo-id": 1533121690,
"event-type": "VariableValueChangeTrigger",
"new-val": "var_becomes_equal_to",
"old-val": "",
"source": "server",
"test-val": "var_becomes_equal_to",
"timestamp": "2025-10-16T13:56:23",
"var-id": 54247914
"change-type": "becomes false",
"change-type-iom": "indigo.kVarChange.BecomesFalse",
"event-indigo-id": 1202935007,
"new-val": "false",
"old-val": "true",
"source": "server",
"timestamp": "2025-10-16T13:56:24",
"var-id": 24284935
"change-type": "becomes greater than",
"change-type-iom": "indigo.kVarChange.BecomesGreaterThan",
"event-indigo-id": 1952491014,
"new-val": "11",
"old-val": "9",
"source": "server",
"test-val": "10",
"timestamp": "2025-10-16T13:56:25",
"var-id": 738010762
"change-type": "becomes less than",
"change-type-iom": "indigo.kVarChange.BecomesLessThan",
"event-indigo-id": 1574402918,
"new-val": "9",
"old-val": "11",
"source": "server",
"test-val": "10",
"timestamp": "2025-10-16T13:56:26",
"var-id": 1177127882
"change-type": "becomes not equal",
"change-type-iom": "indigo.kVarChange.BecomesNotEqual",
"event-indigo-id": 986473566,
"new-val": "",
"old-val": "var_becomes_not_equal_to",
"source": "server",
"test-val": "var_becomes_not_equal_to",
"timestamp": "2025-10-16T13:56:28",
"var-id": 127994353
"change-type": "becomes true",
"change-type-iom": "indigo.kVarChange.BecomesTrue",
"event-indigo-id": 184109916,
"new-val": "true",
"old-val": "false",
"source": "server",
"timestamp": "2025-10-16T13:56:29",
"var-id": 836393156
"change-type-iom": "indigo.kVarChange.Changes",
"event-indigo-id": 127375748,
"new-val": "2025-10-16T13:56:30.146312",
"old-val": "",
"source": "server",
"timestamp": "2025-10-16T13:56:30",
"var-id": 908899214
Z-Wave
"_comment": "This is an example of the event_data from a Z-Wave command received, all event types except match raw (see below)",
"event-indigo-id": 886317539,
"timestamp": "2025-07-25T15:37:14",
"zwavecmd-node-id": 2,
"zwavecmd-scene-id": 255
"_comment": "This is an example of the event_data from a Z-Wave command received, Match Raw Packet",
"event-indigo-id": 572444380,
"timestamp": "2025-07-25T16:44:40",
"zwavecmd-packet": [
1,
9,
0,
4,
0,
2,
3,
38,
3,
58,
242
"zwavecmd-packet-str": "01 09 00 04 00 02 03 26 03 3A F2"
"If you want to get the match string from the trigger, then you can do this:",
" trigger_id = event_data['event-indigo-id'] # get the trigger id",
" firing_trigger = indigo.triggers[trigger_id] # get the trigger instance",
" zwave_plugin_id = event_data['event-plugin-id'] # get the z-wave plugin id",
" zwave_props = firing_trigger.globalProps[zwave_plugin_id] # get the properties",
" match_string = zwave_props['matchBytes'] # get the match string from properties"
