    "foo": 1234567890,
    "bar": "Baz",
Path String Result
bar “Baz”
data [“Thing 1”, “Thing 2”]
more_data['b'] 2
If you want to go deeper into the payload, path strings can be chained together like this:
    "foo": 1234567890,
    "bar": "Baz",
    "data": [
        "Thing 1",
            "Thing A",
            "Thing B",
            "Thing C"
    "more_data": {
        "a": 1,
        "b": 2,
        "c": [
            1,
            2,
            3,
            4,
            5
You can go deeper like this:
Path String Result
data[0] “Thing 1” (The index of the list element, the index starts at zero)
data[1][2] “Thing C” # The second element (index 1) of “data” is a list and the third element (index 2) of that list is “Thing C”
more_data.a 1 # The value of key “a” is 1
more_data.c[3] 4 # The value of key “c” is a list and the fourth element (index 3) of that list is 4
You can chain these path strings as needed, such as some_json[3].a.foo[9]. NOTE: if a path string is not provided, Indigo will return the entire payload. Any path that includes a collection (like the lists and dicts above), Indigo will convert it to JSON and respond with that data.
The following blocks provide samples of event data that Indigo supplies during its operation.
    "_comment": "This is what you get when you execute an action group from the http api",
    "event-indigo-id": 1893263747,
    "event-type": "ActionGroup",
    "source": "api-http",
    "timestamp": "2025-10-16T14:59:05",
    "unique-id": "1dd66fc1-ce8c-43f7-996f-5b29278c1b90"
    "_comment": "When a webhook is called with a JSON dictionary (in data param)",
    "data": {
      "id": "ShortcutWithJsonInputTests.test_webhook_json_input_var_output",
      "message": "something-happened",
      "some-data": {
        "some-key": [
          "some-value",
          "some-other-value"
        "unique-id": "9d34e21b-9926-4023-ab94-c0cc52ecedd5"
    "event-indigo-id": 879507411,
    "event-plugin-event-id": "simpleWebhook",
    "event-plugin-id": "com.indigodomo.webserver",
    "event-plugin-name": "Web Server",
    "http-method": "POST",
    "http-post-content": "JSON",
    "request-url": "https://localhost:8176/webhook/shortcut-json-input-var-output",
    "source": "python",
    "status-code": 200,
    "timestamp": "2025-10-16T14:58:55",
    "webhook-id": "shortcut-json-input-var-output"
Control Page Clicks
  "client-ip": "127.0.0.1",
  "client-is-private": true,
  "control-id": 0,
  "event-indigo-id": 120091806,
  "event-type": "ControlPage",
  "timestamp": "2025-10-16T16:10:54"
Device State Change Trigger
If a device state has any change.
  "_comment": "When the server executes a has any change device state change trigge"
  "change-type": "any change",
  "change-type-iom": "indigo.kStateChange.Changes",
  "device-id": 1167180255,
  "event-indigo-id": 625370601,
  "event-type": "DeviceStateChangeTrigger",
  "new-value": "on",
  "old-value": "off",
  "source": "server",
  "state-key": "onOffState",
  "timestamp": "2025-10-16T17:07:23"
Insteon Command Received
    "_comment": "when any insteon command is received",
    "event-indigo-id": 1086420814,
    "event-type": "InsteonCommandReceivedTrigger",
    "insteon-cmd-rcvd": {
      "Address": 1652724,
      "AddressStr": "19.37.F4",
      "CommandDetails": 0,
      "CommandName": "on",
      "CommandVal": 0,
      "GroupBroadcastNum": 1,
      "IsGroupBroadcast": true,
      "SendCleanups": false
    "source": "server",
    "timestamp": "2025-09-24T15:00:12"
    "_comment": "when a double-tap off command is received"
    "event-indigo-id": 1398699236,
      "Address": 1652724,
      "CommandName": "off (instant)",
      "CommandVal": 0,
    "source": "server",
    "timestamp": "2025-08-12T17:39:49"
Server Executed Schedules
When the server executes a schedule during normal operation.
  "event-indigo-id": 485722026,
  "event-type": "Schedule",
  "source": "server",
  "timestamp": "2025-10-16T13:55:02"
Variable Changes
    "change-type": "becomes equal",
    "change-type-iom": "indigo.kVarChange.BecomesEqual",
    "event-indigo-id": 1533121690,
    "event-type": "VariableValueChangeTrigger",
    "new-val": "var_becomes_equal_to",
    "old-val": "",
    "source": "server",
    "test-val": "var_becomes_equal_to",
    "timestamp": "2025-10-16T13:56:23",
    "var-id": 54247914
    "change-type": "becomes false",
    "change-type-iom": "indigo.kVarChange.BecomesFalse",
    "event-indigo-id": 1202935007,
    "new-val": "false",
    "old-val": "true",
    "source": "server",
    "timestamp": "2025-10-16T13:56:24",
    "var-id": 24284935
    "change-type": "becomes greater than",
    "change-type-iom": "indigo.kVarChange.BecomesGreaterThan",
    "event-indigo-id": 1952491014,
    "new-val": "11",
    "old-val": "9",
    "source": "server",
    "test-val": "10",
    "timestamp": "2025-10-16T13:56:25",
    "var-id": 738010762
    "change-type": "becomes less than",
    "change-type-iom": "indigo.kVarChange.BecomesLessThan",
    "event-indigo-id": 1574402918,
    "new-val": "9",
    "old-val": "11",
    "source": "server",
    "test-val": "10",
    "timestamp": "2025-10-16T13:56:26",
    "var-id": 1177127882
    "change-type": "becomes not equal",
    "change-type-iom": "indigo.kVarChange.BecomesNotEqual",
    "event-indigo-id": 986473566,
    "new-val": "",
    "old-val": "var_becomes_not_equal_to",
    "source": "server",
    "test-val": "var_becomes_not_equal_to",
    "timestamp": "2025-10-16T13:56:28",
    "var-id": 127994353
    "change-type": "becomes true",
    "change-type-iom": "indigo.kVarChange.BecomesTrue",
    "event-indigo-id": 184109916,
    "new-val": "true",
    "old-val": "false",
    "source": "server",
    "timestamp": "2025-10-16T13:56:29",
    "var-id": 836393156
    "change-type-iom": "indigo.kVarChange.Changes",
    "event-indigo-id": 127375748,
    "new-val": "2025-10-16T13:56:30.146312",
    "old-val": "",
    "source": "server",
    "timestamp": "2025-10-16T13:56:30",
    "var-id": 908899214
Z-Wave
    "_comment": "This is an example of the event_data from a Z-Wave command received, all event types except match raw (see below)",
    "event-indigo-id": 886317539,
    "timestamp": "2025-07-25T15:37:14",
    "zwavecmd-node-id": 2,
    "zwavecmd-scene-id": 255
    "_comment": "This is an example of the event_data from a Z-Wave command received, Match Raw Packet",
    "event-indigo-id": 572444380,
    "timestamp": "2025-07-25T16:44:40",
    "zwavecmd-packet": [
      1,
      9,
      0,
      4,
      0,
      2,
      3,
      38,
      3,
      58,
      242
    "zwavecmd-packet-str": "01 09 00 04 00 02 03 26 03 3A F2"
  "If you want to get the match string from the trigger, then you can do this:",
  "    trigger_id = event_data['event-indigo-id']  # get the trigger id",
  "    firing_trigger = indigo.triggers[trigger_id]  # get the trigger instance",
  "    zwave_plugin_id = event_data['event-plugin-id']  # get the z-wave plugin id",
  "    zwave_props = firing_trigger.globalProps[zwave_plugin_id]  # get the properties",
  "    match_string = zwave_props['matchBytes']  # get the match string from properties"
  • /www/perceptive/wiki/data/attic/indigo_2025.1_documentation/events_data_path_specifiers.1761161224.txt.gz
  • Last modified: 2025/10/22 19:27
