Folders
Delete the specified folder.
Get ID
except ValueError, e:
newFolder.refreshFromServer()
# change the name of a folder
newFolder.replaceOnServer()
# duplicate the folder
# delete a folder
  • /www/perceptive/wiki/data/pages/indigo_2025.1_documentation/folder_class.txt
