Getting Started Guide
Z-Wave
  • Thermostats, and
  • Locks.
INSTEON
X10
Other Devices
The Indigo 2025.1 application can be found here:
  /Applications/Indigo 2025.1.app
  /Library/Application Support/Perceptive Automation/Indigo 2025.1/
Time Machine will do this by default. To recover, just recover that directory and then run the Indigo 2025.1 installer again (which will repair any permission issues that Time Machine may have introduced).
Server Folder Change
Web Assets Folder Change
  /Library/Application Support/Perceptive Automation/Indigo 2025.1/Web Assets/
  1. Deactivate Indigo on your Mac by selecting the Indigo 2025.1→License Details… menu item and clicking the Deactivate License button. Do this while the Indigo Server is still running (do not shutdown the Indigo Server first)
  2. Copy this folder over to the new Mac: /Library/Application Support/Perceptive Automation/Indigo 2025.1/ (if restoring from a backup, you'll need to locate this folder in whatever backup system you use)
  3. Install Indigo 2025.1 on the new Mac (download and run the installer - you must be logged in to your Indigo Account to see all the installers available to you)
To uninstall the Indigo Server and all of its data and configuration files, first deactivate Indigo on your Mac by selecting the Indigo 2025.1→License Details… menu item and clicking the Deactivate License button. You'll get the following warning dialog:
Deactivate Sheet Image
Then make sure that you have the server and client completely shut down (select Stop Server from the Indigo 2025.1 menu if the server is still running before you quit the Indigo Mac Client).
  • /Library/Application Support/Perceptive Automation/Indigo 2025.1/
  • Optional : If you don't use Python 3.11 for anything (other than Indigo 2025.1), you can delete this folder: /Library/Frameworks/Python.framework/Versions/3.11 and this file: /Library/Frameworks/Python.framework/Versions/Current Note: this will leave any other version of Python alone including any previous versions that older Indigo installs may have installed (if you plan on reverting to an older version). To completely remove all Python installations that any version of Indigo may have installed, just delete the entire Python framework: /Library/Frameworks/Python.framework
  • /Applications/Indigo 2025.1.app
  • ~(your user folder)/Library/Preferences/com.perceptiveautomation.indigo-2025-1.plist
  • ~(your user folder)/Library/Preferences/Indigo 2025.1 Client Prefs.indiPref
  • ~(your user folder)/Library/Preferences/Indigo 2025.1 Client Settings.indiPref
To uninstall older versions but leave 2025.1 installed correctly, delete these:
  • Indigo 2024.2:
    • /Applications/Indigo 2024.2.app
  • Indigo 2024.1:
    • /Applications/Indigo 2024.1.app
  • Indigo 2023.2:
  • Indigo 2023.1:
  • Indigo 2022.2:
  • Indigo 2022.1:
  • Indigo 2021.2:
  • Indigo 2021.1:
  • Indigo 7.5:
  • Indigo 7.4:
  • Indigo 7.3:
  • Indigo 7.2:
  • Indigo 7.0 and 7.1:
    • /Applications/Indigo 7.app
    • /Applications/Indigo 6.app
  1. Double click the Indigo 2025.1 application (/Applications/Indigo 2025.1.app).
  2. If this is the first time to run Indigo 2025.1 on this Mac, then press the Start Local Server… button in the connection status window.
  3. If you want to reconfigure the Indigo Server on a Mac already running Indigo, then select the Indigo 2025.1→Start Local Server… menu item.
Start Server Dialog Image
Login Dialog Image
Firewall Prompt Image
IPH Firewall Prompt Image
Network WiFi Image
Network Wired Image
  2. Double click the Indigo 2025.1 application (inside /Applications/Indigo 2025.1.app) on the remote Mac.
  4. If you are wanting to connect to a different Indigo Server, then select the Indigo 2025.1→Connect to Remote Server… menu item.
  7. Press the Connect button.
Client Connect Dialog Image
 http://192.168.1.23:8176/
Interfaces Menu Image
Interfaces Tab Image
  9. NOTE: due to a bug in some macOS releases, this step may try to launch a previous version of Indigo. If it does, quit it, then right-click the plugin file, select the Open With menu item, then select Indigo 2024.1.Open With Menu Item Image
  11. Done!
Plugin Configuration Dialog
Main Plugins Menu
Plugins Menu Image
Individual Plugin Submenu
Plugin Enabled Submenu Image
The next section contains:
Other Menus with Plugin Items
Plugin New Device Image
Plugin Events Image
Plugin Actions Image
Plugins Tab Image
  2. Switch back to Indigo and shut down the Indigo Server by selecting the Indigo 2024.1→Stop Server menu item in the Mac client (you can leave the client app running).
  4. Switch back to the Indigo 2024.1 Mac client and click on the Start Local Server… button in the Server Connection Status dialog.
Location Services Image
Longitude Latitude Tab Image
  • Choose the Indigo 2024.1→Preferences… menu item, then make sure the Sunset & Sunrise tab is selected.
General Preferences Tab Image
  • /www/perceptive/wiki/data/attic/indigo_2025.1_documentation/getting_started.1758571101.txt.gz
