Getting Started Guide
Welcome to Indigo 2025.1!
- Mac OS X 10.12 or higher
Z-Wave
- Thermostats, and
- Locks.
INSTEON
X10
Other Devices
Other Sources for Help
Installing Indigo
The Indigo 2025.1 application can be found here:
/Applications/Indigo 2025.1.app
/Library/Application Support/Perceptive Automation/Indigo 2025.1/
Backing Up Indigo
Time Machine will do this by default. To recover, just recover that directory and then run the Indigo 2025.1 installer again (which will repair any permission issues that Time Machine may have introduced).
Server Folder Change
Web Assets Folder Change
/Library/Application Support/Perceptive Automation/Indigo 2025.1/Web Assets/
Indigo 2025.1→License Details…menu item and clicking theDeactivate Licensebutton. Do this while the Indigo Server is still running (do not shutdown the Indigo Server first) - Copy this folder over to the new Mac:
/Library/Application Support/Perceptive Automation/Indigo 2025.1/(if restoring from a backup, you'll need to locate this folder in whatever backup system you use) - Install Indigo 2025.1 on the new Mac (download and run the installer - you must be logged in to your Indigo Account to see all the installers available to you)
- manually remove the
Uninstalling Indigo
Uninstalling the Server
To uninstall the Indigo Server and all of its data and configuration files, first deactivate Indigo on your Mac by selecting the Indigo 2025.1→License Details… menu item and clicking the Deactivate License button. You'll get the following warning dialog:
Then make sure that you have the server and client completely shut down (select Stop Server from the Indigo 2025.1 menu if the server is still running before you quit the Indigo Mac Client).
/Library/Application Support/Perceptive Automation/Indigo 2025.1/~(your user folder)/Library/LaunchAgents/com.perceptiveautomation.IndigoServer2.plist- Optional : If you don't use Python 3.11 for anything (other than Indigo 2025.1), you can delete this folder:
Uninstalling the Mac Client
/Applications/Indigo 2025.1.app~(your user folder)/Library/Preferences/com.perceptiveautomation.indigo-2025-1.plist~(your user folder)/Library/Preferences/Indigo 2025.1 Client Prefs.indiPref~(your user folder)/Library/Preferences/Indigo 2025.1 Client Settings.indiPref
To uninstall older versions but leave 2025.1 installed correctly, delete these:
- Indigo 2024.2:
/Library/Application Support/Perceptive Automation/Indigo 2023.2//Applications/Indigo 2024.2.app
- Indigo 2024.1:
/Library/Application Support/Perceptive Automation/Indigo 2023.2//Applications/Indigo 2024.1.app
- Indigo 2023.2:
- Indigo 2023.1:
- Indigo 2022.2:
- Indigo 2022.1:
- Indigo 2021.2:
- Indigo 2021.1:
- Indigo 7.5:
- Indigo 7.4:
- Indigo 7.3:
- Indigo 7.2:
- Indigo 7.0 and 7.1:
Starting Indigo Server
- Double click the
Indigo 2025.1application (/Applications/Indigo 2025.1.app). - If this is the first time to run
Indigo 2025.1on this Mac, then press theStart Local Server…button in the connection status window. - If you want to reconfigure the Indigo Server on a Mac already running Indigo, then select the
Indigo 2025.1→Start Local Server…menu item.
Standard startup mode
Custom single app startup
Starting the Server
Remote Indigo Access
Modifying Firewall Settings
- Double click the
Indigo 2025.1application (inside/Applications/Indigo 2025.1.app) on the remote Mac. - If this is the first time to run
Indigo 2025.1→Connect to Remote Server…menu item. - Enter the
Connectbutton.
http://192.168.1.23:8176/
Managing Plugins
Installing/Updating Plugins
- Click the
.indigoPlugin. Double-click that file.
- You will be switched to the Indigo Client app, and you'll a dialog window which asks you if you want to install and enable the plugin. You will see a different dialog if the version number is lower than an already-installed version; for safety, Indigo will ask you to confirm that you want to downgrade the plugin.
- NOTE: due to a bug in some macOS releases, this step may try to launch a previous version of Indigo. If it does, quit it, then right-click the plugin file, select the
Open Withmenu item, then select Indigo 2024.1.
- Click the
Plugin Menus in Indigo
Main Plugins Menu
Individual Plugin Submenu
The next section contains:
- the
Other Menus with Plugin Items
- the
Uninstalling a Plugin
Indigo 2024.1→Stop Servermenu item in the Mac client (you can leave the client app running). - In the Finder window opened in step 1, you'll see two folders:
PluginsandPlugins (Disabled). Depending on whether the plugin is enabled or not will determine which folder it's in. Open the appropriate folder and delete the unwanted plugin. Check to make sure that somehow there aren't plugins in both locations. - Switch back to the Indigo 2024.1 Mac client and click on the
- Choose
Date & Timeicon. - Select the
- Choose the
Indigo 2024.1→Preferences…menu item, then make sure theSunset & Sunrisetab is selected. - Select the
- Choose
Energy Savericon. - Move the
Where to Go Next
