Glossary of Terms
Term Definition
Action Indigo actions are discrete tasks that cause things to happen – such as turning on a light, changing a setpoint, writing information to the log, and so on. Indigo ships with many standard actions and plugin developers can create actions that apply to their plugins.
Condition In Indigo, a condition is a logical test that's used to determine whether something should happen. For example, you might only want something to happen at nighttime, or only when all the windows are closed.
Controller In Indigo, a controller is a device that controls another device. Z-Wave controllers include various peripherals such as USB sticks – which send commands from Indigo to a device (like a dimmer) or from the device to Indigo. A controller may also be a responder (i.e. INSTEON KeypadLinc). We've adopted the term from various INSTEON documentation.
Developer A person who writes plugins or scripts for the Indigo Server (IS).
Device A device is any “thing” that Indigo can interact with - usually it's some kind of hardware (light switch, appliance module, motion sensor, etc), but devices can also be other non-hardware things (iTunes server, calendar, etc). Devices can also be “virtual” objects supported by plugins that have the potential to do all kinds of useful things.
Indigo Object Model The Indigo Object Model (IOM) is how the various objects in Indigo are modeled in Python objects for scripters and plugin developers.
Plugin Indigo supports ways to extend its functionality such as Indigo Server (IS) plugins. IS plugins can extend Indigo by adding additional devices types, trigger events, and actions.
Responder In Indigo terminology, it's a device that responds to commands. A responder may also be a controller (i.e. INSTEON KeypadLinc). We've adopted the term from various INSTEON documentation.
Scripter Someone who uses Python scripts to implement automation logic in Indigo via embedded or file-based script actions and script conditions.
Trigger A trigger is generally some kind of “event” that occurs. Indigo can use that event to execute actions in response. For example, turn on an exhaust fan if the humidity exceeds a certain level.
Variable A variable is a place where your home automation logic can store information that changes during the normal operation of your home and that can be used in other parts of your system: for instance, you can have a variable that represents whether your home is occupied or not - then you can have special automation logic that takes place when that variable changes. Indigo variables store values as plain text.
  • /www/perceptive/wiki/data/pages/indigo_2025.1_documentation/glossary_of_terms.txt
