Indigo Touch For Web
Loading ITW
https://my_reflector.indigodomo.netvia a securehttps://connection (the reflector service requires an Indigo up-to-date subscription). - a local loop-back address such as
http://localhost:8176orhttp://127.0.0.1:8176via an insecurehttp:connection. These connections are only valid when used on the same machine running the Indigo server (and obviously, won't work on mobile). - a direct IP address such as
http://10.0.1.123:8176orhttp://192.168.0.123:8176via an insecurehttp:connection.
Interface Controls
Tabs
- The Devices tab shows the devices in the Indigo database.
- Only devices with
Remote Displaychecked will be displayed. - Many device controls are available in ITW, including:
- On/off
- Lock/unlock
- Dimming
- Thermostat
Devices also have a special popup menu which is shown when you click the ellipsis icon … at the top of the device tile. This displays a menu with up to four options (depending on the type of device):
- Copy ID - This item will cause the device's ID to be copied to the clipboard. Due to the security of modern browsers, this feature will only work via
httpsconnections via the Indigo Reflector Service and viahttpwhen connecting using a local loopback address likelocalhostor127.0.0.1. - Refresh from server - ITW objects update automatically when data are changed in Indigo, but sometimes you might want to force the data to refresh for a specific device. Selecting this item will cause the device data to be refreshed.
- Show device JSON - this item will cause a pop-up window to display the entire JSON payload for the device.
Actions
- The Actions tab shows the action groups in the Indigo database.
- Only actions with
Remote Displaychecked will be displayed. - Clicking a displayed action button will cause the action to be executed.
Variables
- The Variables tab shows all the variables in the Indigo database.
- Only variables with
Remote Displaychecked will be displayed. - You can change the value of any variable (with the sole exception of
isDaylightwhich is read only). Clicking on a variable value will cause a dialog box to open where you can edit the value. Note: it's possible for the value to change on the Indigo server while you are editing it. In instances where this happens, the last write will take precedence. In other words, if you click save in ITW after the value has changed on the server, the ITW value will become the new value. - For select boolean values, a toggle value button will be displayed in the editing dialog–similar to Indigo Touch.
Triggers
- The Triggers tab shows all the triggers in the Indigo database.
- Triggers don't have a
Remote Displaycheckbox, so no triggers are hidden from view. - Disabled triggers are shown with a red border.
- Clicking a displayed trigger button will cause the associated events to be executed.
Schedules
- The Schedules tab shows all the schedules in the Indigo database.
- Schedules don't have a
Remote Displaycheckbox, so no schedules are hidden from view. - Disabled schedules are shown with a red border.
- Clicking a displayed schedule button will cause the associated events to be executed.
Pages
- The Pages tab shows control pages in the Indigo database.
- Only control pages with
Remote Displaychecked will be displayed. - Clicking a displayed control page button will cause the page to be loaded in a separate window or tab.
Logs
- The Logs tab begins with the 25 most recent event log entries.
- New log messages will be displayed while the Logs tab is active.
- Debug, caution and warning messages will be colored appropriately.
In Folder
Name Contains
Light Mode and Dark Mode
Tile View / List View
Loading A Specific Tab
Examples:
| Devices | http://localhost:8176/index.html?tab=devices | X |
| Actions | http://127.0.0.1:8176/index.html?tab=actions | |
| Variables | https://my_reflector.indigodomo.net/index.html?tab=variables | |
| Pages | http://192.168.0.123:8176/index.html?tab=pages | |
| Logs | http://10.0.1.123:8176/index.html?tab=logs |
Troubleshooting
https://when accessing via the Indigo Reflector Service, andhttp://via the other available means.
- be sure you've entered the correct address for your Indigo server and the port number you specified when you started the server (the default is 8176).
- if the proper tab wasn't selected when you loaded the app, be sure your query arguments are lowercase…
