Indigo Touch Web Image
  1. the Indigo Reflector Service using your custom reflector address such as https://my_reflector.indigodomo.net via a secure https:// connection (the reflector service requires an Indigo up-to-date subscription).
  2. a local loop-back address such as http://localhost:8176 or http://127.0.0.1:8176 via an insecure http: connection. These connections are only valid when used on the same machine running the Indigo server (and obviously, won't work on mobile).
  3. a direct IP address such as http://10.0.1.123:8176 or http://192.168.0.123:8176 via an insecure http: connection.
Tabs
  • The Devices tab shows the devices in the Indigo database.
  • Only devices with Remote Display checked will be displayed.
  • Many device controls are available in ITW, including:
    • On/off
    • Lock/unlock
    • Dimming
    • Thermostat
Devices also have a special popup menu which is shown when you click the ellipsis icon at the top (or on the right side) of the device tile. This displays a menu with up to four options (depending on the type of device):
  • Copy ID - This item will cause the device's ID to be copied to the clipboard. Due to the security of modern browsers, this feature will only work via https connections via the Indigo Reflector Service and via http when connecting using a local loopback address like localhost or 127.0.0.1.
  • Refresh from server - ITW objects update automatically when data are changed in Indigo, but sometimes you might want to force the data to refresh for a specific device. Selecting this item will cause the device data to be refreshed.
  • Send status request - only available for devices that support the Send Status Request feature in the Indigo Client.
  • Show device JSON - this item will cause a pop-up window to display the entire JSON payload for the device.
Actions
  • The Actions tab shows the action groups in the Indigo database.
  • Only actions with Remote Display checked will be displayed.
  • Clicking a displayed action button will cause the action to be executed.
Variables
  • The Variables tab shows all the variables in the Indigo database.
  • Only variables with Remote Display checked will be displayed.
  • You can change the value of any variable (with the sole exception of isDaylight which is read only). Clicking on a variable value will cause a dialog box to open where you can edit the value. Note: it's possible for the value to change on the Indigo server while you are editing it. In instances where this happens, the last write will take precedence. In other words, if you click save in ITW after the value has changed on the server, the ITW value will become the new value.
  • For select boolean values, a toggle value button will be displayed in the editing dialog–similar to Indigo Touch.
Variables also have a special popup menu which is shown when you click the ellipsis icon on the right side of the variable tile. This displays a menu with two options:
  • Copy ID: This option will copy the variable's ID to the clipboard.
  • Copy value: This option will copy the variable's value to the clipboard.
Due to the security of modern browsers, these features will only work via https connections or via http when connecting using a local loopback address like localhost or 127.0.0.1.
Triggers
  • The Triggers tab shows all the triggers in the Indigo database.
  • Triggers don't have a Remote Display checkbox, so no triggers are hidden from view.
  • Disabled triggers are shown with a red border.
  • Clicking a displayed trigger button will cause the associated events to be executed.
Schedules
  • The Schedules tab shows all the schedules in the Indigo database.
  • Schedules don't have a Remote Display checkbox, so no schedules are hidden from view.
  • Disabled schedules are shown with a red border.
  • Clicking a displayed schedule button will cause the associated events to be executed.
Pages
  • The Pages tab shows control pages in the Indigo database.
  • Only control pages with Remote Display checked will be displayed.
  • Clicking a displayed control page button will cause the page to be loaded in a separate window or tab.
Logs
  • The Logs tab begins with the 25 most recent event log entries.
  • New log messages will be displayed while the Logs tab is active.
  • Debug, caution and warning messages will be colored appropriately.
  • Long and multiline log messages will be truncated, and will appear with an ellipsis (…). Clicking on a truncated message will expand it. Click again to collapse it.
In Folder
Name Contains
Light Mode Dark Mode
Indigo Touch Web Image Light Indigo Touch Web Image Dark
Tile View List View
Indigo Touch Web Tile View Indigo Touch Web List View
Items in List view are collapsed by default. Clicking on the “>” next to an item will expand it to display things like additional controls and details. Click on the element's “>” again to collapse it.
Examples:
Tab Target URL Default
Devices http://localhost:8176/index.html?tab=devices X
Actions http://127.0.0.1:8176/index.html?tab=actions
Variables https://my_reflector.indigodomo.net/index.html?tab=variables
Pages http://192.168.0.123:8176/index.html?tab=pages
Logs http://10.0.1.123:8176/index.html?tab=logs
    • https:// when accessing via the Indigo Reflector Service, and
    • http:// via the other available means.
  • be sure you've entered the correct address for your Indigo server and the port number you specified when you started the server (the default is 8176).
  • if the proper tab wasn't selected when you loaded the app, be sure your query arguments are lowercase… ?tab=logs is valid, ?tab=Logs is not.
  • /www/perceptive/wiki/data/attic/indigo_2025.1_documentation/indigo_touch_web.1761306904.txt.gz
  • Last modified: 2025/10/24 11:55
