Indigo Object Model Reference
# some code here
# that does something
TermMeaning
For Scripters and Developers:
For Developers:
ClassCommand namespaceNotes
Schedule
Triggers
DeviceStateChangeTrigger (indigo.DeviceStateChangeTrigger)indigo.devStateChange.*manipulate a device state change trigger
Variables
Protocol Specific Commands
General Commands
There are a few classes that are special. One is Action and it’s subclasses (collectively referred to as “actions”). Why are these classes different? Because outside of the trigger, schedule, action group, or control page that they’re associated with they aren’t individually addressable in the IndigoServer: for instance, there is no way to identify an action without first identifying the trigger that it’s associated with.
IOM Object Hierarchy Image
  • keys cannot contain spaces.
c = indigo.List()
c.append(4)
c.append(5)
c.append(True)
c.append(False)
a = indigo.Dict()
a['a'] = "the letter a"
a['b'] = False
print(str(a))
c.append(6)
a['c'].append(6)
a['c'] = c
print(str(a))
Object Description
Object Events
Objects that support subscribeTochanges()
Lower-level Events
Low Level Commands (Insteon and x10 Only)
indigo.x10.subscribeToIncoming()
indigo.x10.subscribeToOutgoing()
        if cmd.cmdType == "sec":    # or "x10" for power line commands
            if cmd.secCodeId == 6:
Iterating Object Lists
for dev in indigo.devices:
    # do stuff with dev here
Filter Description
indigo.x10include X10 devices
indigo.dimmerdimmer devices
indigo.sprinklersprinklers
indigo.thermostatthermostats
Triggers also have filters:
Filter Description
for var in indigo.variables:
    # all variables
Possible Exceptions
>>> dev.__class__
<class 'indigo.DimmerDevice'>
>>> hasattr(dev,'onState')
True
>>> dir(dev)
>>> thermo.__class__
>>> dir(thermo)
>>> tunes.__class__
<class 'indigo.Device'>
>>> dir(tunes)
>>> tunes.deviceTypeId
u'mediaserver'
>>> dev = indigo.devices[123]
address :
batteryLevel : None
buttonGroupCount : 0
configured : True
description :
<'indigo.Device'>
>>> dev_dict = dict(dev)
<class 'dict'>
Name Base Description
FileNotFoundErrorException This is a useful exception if you handle files in any way. There is no built-in processing to catch such exceptions, it's just a useful exception to use.
IndigoJSONEncoderJSONEncoder Use this encoder class if you are encoding a python date, time, or datetime class into a JSON string. Very useful if you attempt to encode a device dictionary into JSON (json.dumps(dict(mydevice), cls=indigo.utils.IndigoJSONEncoder))
Return Static File
status No int the HTTP status code to return, defaults to 200
path_is_relative No boolean is the path a full path or relative to the plugin, defaults to True
content_type No string a string to return as the mime type of the content, returns the appropriate type based on the file extension if none is specified
    "status": 404,
    "headers": {
        "Content-Type": "text/html"
    "file_path": "/Library/Application Support/Perceptive Automation/Indigo 2025.1/Plugins/Example HTTP Responder.indigoPlugin/Contents/Resources/static/html/static_404.html"
Validate Email Address
indigo.utils.validate_email_address("[email protected]")
Boolean Functions
There are two functions available that will help scripters and developers in converting and using strings that represent boolean values, but are not True and False.
The first is str_to_bool(val: str). It will convert the string passed in to a boolean value and return it. We use the following map and it's reverse to do the mapping:
BOOL_MAP_TRUE: dict[str, str] = {
    "y": "n",
    "yes": "no",
    "t": "f",
    "true": "false",
    "on": "off",
    "1": "0",
    "open": "closed",
    "locked": "unlocked",
indigo.utils.str_to_bool("closed")
val Yes string a string that represents a boolean value as mapped above
Returns True for true values, False for values that are false, and will raise an indigo.utils.ValueError if the input can't be successfully converted.
The second is reverse_bool_str_value(val: str). It will return the string that represents the opposite boolean value using the map above.
indigo.utils.reverse_bool_str_value("closed")
val Yes string a string that represents a boolean value for which we want the opposite string value
This example returns open since that's the opposite of closed. It will raise an indigo.utils.ValueError if the input can't be successfully found.
  • /www/perceptive/wiki/data/pages/indigo_2025.1_documentation/object_model_reference.txt
  • Last modified: 2025/10/22 20:09
  • by jay
