Indigo Scripting Tutorial
Turn off all devices:
indigo.device.allOff()
indigo.devices.len()
if hasattr(lamp, 'onState'):
    isOn = lamp.onState
from datetime import datetime
Access a custom device state
# get the device
# show all the device states:
print(dev.states)
myVar = indigo.variables[123]
if myVar.value == "true":
Duplicating a variable:
import requests
my_unicode_string = "éçø"
my_integer = 1
my_float = 1.0
import json
my_new_dictionary["my_list"]
class myCustomClass:
    def __init__(self):
        self.a=1
        self.b=2
    def __str__(self):
        return outputString
cl = myCustomClass()
Get the current server time:
indigo.server.getTime()
import datetime
import logging
print(logList)
except ValueError as e:
        myFolder = None
if lamp.folderId != 0:
    lampsFolder = None
Event Data Examples
Webhook events pass data along the chain that can be easily accessed in embedded or linked scripts. The data is passed first to any conditional scripts. The event data can have many forms, but certain data will be passed regardless of the source of the call. By default, every event dictionary will contain the following:
A more robust event dictionary might look like this:
     "data": (dict)
     "event-indigo-id": 1234567890 (integer)
     "event-plugin-event-id": simpleWebhook (string)
     "event-plugin-id": com.indigodomo.webserver (string)
     "event-plugin-name": Web Server (string)
     "event-type": PluginEventTrigger (string)
     "http-method": GET (string)
     "request-url": https://localhost:8176/webhook/8143484549824dbba1286a873daa3cea (string)
     "source": python (string)
     "status-code": 200 (integer)
     "timestamp": 2025-10-21T21:20:50 (string)
     "webhook-id": 8143484549824dbba1286a873daa3cea (string)
Regardless of where the data came from (trigger, schedule, etc), the variable name will be event_data. The data can be accessed like this:
# If you did a indigo.actionGroup.execute(12345) the source would be `python`.
# You don't need to import `event data`, it will be made available automatically.
if event_data["source"] == "python":
    indigo.server.log(f"{event_data['timestamp']}")  # or whatever
All event_data payloads will be formatted as <class 'indigo.Dict'>.
Sending emails
# Simple Example
/usr/local/indigo/indigo-host
Plugin Host Prompt Image
indigo-host -e '
indigo_attachments.py
    import indigo
except ImportError:
    raise ImportError
def log(message, label=None):
import indigo_attachments
    raise ImportError
ImportError
Method Description
restart(waitUntilDone=True) This method will restart the plugin if it's already running. Pass the optional parameter waitUntilDone=False if you don't want to block while the plugin restarts (waitUntilDone defaults to True if it's no parameters are passed). If you're a plugin developer and you want to restart the plugin from within itself you should pass that parameter.
Plugin actions may return a value (a Python “primitive”) when you call the executeAction method, but they are not required to. The return value can be any one of the following object types:
  • None None,
  • booleans bool,
  • integers int(),
  • floats float(),
  • strings str(),
  • Indigo Dicts indigo.Dict(),
  • Indigo Lists indigo.List().
Restart a Plugin
    airfoil_plugin.restart()
Wait Until Done
if airfoilPlugin.isEnabled():
            'getSources',
            waitUntilDone=True
    except Exception as e:
     audioDevices : (list)
          Item : (dict)
               icon : [SNIP]
          Item : (dict)
               icon : [SNIP]
          Item : (dict)
               icon : [SNIP]
     recentApplications : (list)
          Item : (dict)
               icon : [SNIP]
          Item : (dict)
               icon : [SNIP]
    systemAudio : (list)
    	  Item : (dict)
    	  	   icon : [SNIP]
  • /www/perceptive/wiki/data/attic/indigo_2025.1_documentation/plugin_scripting_tutorial.1761100986.txt.gz
  • Last modified: 2025/10/22 02:43
