  1. To duplicate, delete, and send commands to a schedule, use the command namespace as described below
  2. To modify an object's definition, get a copy of the schedule, make the necessary changes, then call mySchedule.replaceSharedPropsOnServer(newPropsDict) (see below).
Under construction
absoluteDate datetime.datetime / None Yes The absolute date of the next schedule execution with 00:00:00 as the base time.
absoluteDateTime datetime.datetime / None Yes The absolute date and time of the next schedule execution.
absoluteTime datetime.datetime / None Yes The absolute time of the next schedule execution with 2000-01-01 as the base date.
autoDelete boolean Yes true if Indigo should automatically delete this schedule after the next execution, otherwise false.
configured boolean Yes true if the schedule has been fully configured, otherwise false.
dateType indigo.kDateType / None Describes the “type” of date/time options for the schedule. [Absolute / EveryDay / DaysOfWeek / DaysOfMonth]
description string Yes description of the schedule.
enabled boolean Yes true if the schedule is enabled, otherwise false (Indigo will not execute the schedule if false).
folderId integer No unique ID of the folder this schedule is in.
globalProps dictionary No an indigo.Dict() that will contain the props for the schedule. It's generally easier to use the shortcut sharedProps below.
id integer No a unique id of the schedule, assigned on creation by IndigoServer.
name string Yes the unique name of the schedule - no two schedules can have the same name.
nextExecution datetime.datetime / None No The date and time of the schedule's next execution.
pluginProps dictionary No pluginProps will return an empty dict because plugins cannot currently create custom schedules.
remoteDisplay boolean Yes true if remote clients should display the schedule, otherwise false (does not affect the Indigo client UI.
sharedProps dictionary No an indigo.Dict() containing the name/value pairs that are shared by all plugins. This is the property dictionary that you can edit via the Global Properties plugin, and your plugin may manage properties in this dictionary as well to add metadata to devices that your plugin can use for other purposes. Use sched.replaceSharedPropsOnServer() to update them (as with pluginProps, you should get copy first, update the copy, then set them back to that copy so you don't accidentally remove some other plugin's props).
sunDelta integer Yes The number of seconds before (negative) or after (positive) sunrise or sunset when the schedule should be executed (zero if no offset).
suppressLogging boolean Yes true if Indigo should skip logging the schedule's execution in the event log, otherwise false.
timeType indigo.kTimeType Yes Absolute / Sunrise / Sunset / Countdown depending on the date and time options selected.
upload boolean Yes true if IndigoServer should attempt to upload this schedule to the interface.
indigo.schedule.delete(123)
Enable
schedule_data No object an indigo.Dict to be passed to the schedule before it is executed
  • “server” if it's something generated from the server itself (schedule execution, built-in trigger, etc)
  • “python” if it's something that comes through IPH that doesn't already have a source attached (scripts, plugins)
  • “api-http” if it came from the HTTP API and there wasn't already an included “source”
  • “api-websocket” if it came from the websocket API and there wasn't already an included “source”
For example, if you
my_dict = indigo.Dict()
my_dict["foo"] = "bar"
indigo.schedule.execute(324976872, schedule_data=my_dict)
Move to Folder
  • /www/perceptive/wiki/data/pages/indigo_2025.1_documentation/schedule_class.txt
  • Last modified: 2026/02/19 21:11
