  1. To create, duplicate, delete, and send commands to a schedule, use the command namespace as described below
Under construction
absoluteDate datetime.datetime / None
absoluteDateTime datetime.datetime / None
absoluteTime datetime.datetime / None
autoDelete boolean
configured boolean
dateType indigo.kDateType / None
enabled boolean Yes
folderId integer No unique ID of the folder this schedule is in
globalProps dictionary No
id integer No a unique id of the schedule, assigned on creation by IndigoServer
name string Yes the unique name of the schedule - no two schedules can have the same name
nextExecution datetime.datetime / None
pluginProps dictionary No
randomizeBy integer
remoteDisplay boolean
sharedProps dictionary No
sunDelta integer
suppressLogging boolean Yes
timeType indigo.kTimeType
upload boolean Yes true if IndigoServer should attempt to upload this schedule to the interface
indigo.schedule.delete(123)
Enable
schedule_data No object data to be passed to the schedule before it is executed
Move to Folder
Move to Folder
  • /www/perceptive/wiki/data/attic/indigo_2025.1_documentation/schedule_class.1771467778.txt.gz
  • Last modified: 2026/02/19 02:22
