To create, duplicate, delete, and send commands to a schedule, use the command namespace as described below
To modify an object's definition, get a copy of the schedule, make the necessary changes, then call mySchedule.replaceOnServer(newPropsDict)
To update a plugin's props on a trigger, call myTrigger.replacePluginPropsOnServer(newPropsDict) rather than try to update them on the local trigger
Under construction
absoluteDate | datetime.datetime / None | | |
absoluteDateTime | datetime.datetime / None | | |
absoluteTime | datetime.datetime / None | | |
dateType | indigo.kDateType / None | | |
enabled | boolean | Yes | |
nextExecution | datetime.datetime / None | | |
randomizeBy | integer | | |
remoteDisplay | boolean | | |
sunDelta | integer | | |
suppressLogging | boolean | Yes | |
timeType | indigo.kTimeType | | |
Commands (indigo.schedule.*)
indigo.schedule.delete(123)
| Parameters |
| Parameters |
Enable
| Parameters |
| Parameters |
schedule_data | No | object | data to be passed to the schedule before it is executed |
| Parameters |
Move to Folder
| Parameters | |
Move to Folder
| Parameters |
